Old 06-18-2016, 06:48   #1 (permalink)
nongmobile's Avatar
Member: 716581
Thanks Meter: 734
Read Flash Fail !! pls FIX.
Start at : [18/6/2016 / 12:29:47]
Operation : Read Flash [ v1.50 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 460001154D32323724D2004265A184F2
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM227
[eMMC] : FLASH_CID : 150100463732324D4200D224F284C265
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x8DAB37EEE991889EE490E954932186F4
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
xGPT : Normalize settings Ok!
Brand : iris 550
ProdName : iris 550
ProdModel : iris 550
Device : lava35m_sp48
AndroidVer: 5.1
MTKxCPU : MT6735
MTKxPRJ : ALPS.L1.MP3.V2_LAVA6735.64.L1_P23
[Read Ok] : preloader_lava35m_sp48.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
Fatal error, buffer empty! Phone connection lost???
Error while reading block! Something went wrong
Read error
Operation Failed
BUT AB.. DONE
Reinsert phone battery.
Battery must be charged.
Phone must be off with battery inside.
Please insert USB cable now...
Detected : PreLoader USB VCOM Port (COM7)
Phone detected...Please wait
Sending DA agent, please wait...
BaseBand CPU :MT6735M_S00
BaseBand CPU Secure Version : FF
BaseBand CPU Bootloader Version : 01
INT RAM: 128 KB SDRAM
EXT RAM: 1 GB DRAM
EMMC: (58Gb+8192Mb) SAMSUNG 0x463732324d42
EMMC FW VERSION: 00:00:00:00:00:00:00:00
EMMC CID: 15010046373232 : 000000000000000000
EMMC UA SIZE: 0x1d2000000
BOOT STYLE: EMMC BOOT
FULL LENGTH: 0x1d2880000 [7.290 GB]
Detecting high speed port, wait......
If driver not installed, install high speed port driver.
If not need high speed port, disable it.
After repeat opperation.
Detected : DA USB VCOM Port (COM25)
IMEI[1]: 911483352052506
IMEI[2]: 911483352052506
Dumping Preloader.
Start dumping flash, this can take up to 1 hour.......
Start procesing proinfo
Reading: BEGIN: 0x80000 - LEN: 0x1000
Start procesing nvram
IMEI[1] from NVRAM: 911483352052506
IMEI[2] from NVRAM: 911483352052506
Start procesing protect1 ......
Reading: BEGIN: 0x880000 - LEN: 0xa00000
Start procesing protect2 ......
Reading: BEGIN: 0x1280000 - LEN: 0xa00000
Start procesing lk ......
Start processing boot
Start processing recovery
Start procesing logo ......
Start procesing secro
Start procesing tee1
Start procesing tee2
Start procesing frp ......
Reading: BEGIN: 0x6a00000 - LEN: 0x100000
Start procesing nvdata ......
Reading: BEGIN: 0x6b00000 - LEN: 0x2000000
Start procesing system
Reading: BEGIN: 0xb000000 - LEN: 0xa0000000
Backup cache disabled, we will skip it....
Backup userdata disabled, we will skip it....
Saved to : C:\Users\nOng\Documents\Android_MTK\firmware_backu p\MT6735M_S00_EMMC_911483352052506_911483352052506 _06_18_2016_11_47_12
Wait untill phone will start charging.
Old 06-18-2016, 07:33   #2 (permalink)
pradeep_kus's Avatar
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,450
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : iris 550
ProdName : iris 550
AndroidVer: 5.1
MTKxCPU : MT6735
[Read Ok] : lk.bin
Read error
Operation Failed
BUT AB.. DONE
EXT RAM: 1 GB DRAM
Dumping Preloader.
Hello,
i do not know AB
for cm2
try again with another usb cable , connection lost between pc or phone
Old 06-18-2016, 08:41   #3 (permalink)
nongmobile's Avatar
Member: 716581
Thanks Meter: 734
AB = AVB = avenger box read DONE
Same Phone , Same USB cable , Same PC and More Try.
Old 06-18-2016, 09:40   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,192
Bad luck then. There is nothing to fix.
Old 06-18-2016, 15:16   #5 (permalink)
nongmobile's Avatar
Member: 716581
Thanks Meter: 734
Best Support not work but nothing to fix. i sell you many dongle in thailand but when i have problem and my customer have problem and i report you tell nothing to fix. you think you software perfect? NO!!!
Nothing to fix why version 1.37 not fail ????
Old 06-18-2016, 15:38   #6 (permalink)
JayDi's Avatar
Member: 462970
Just for your info - I haven't asked you sell anything. So, try find more better arguments.
Next time, instead of making comprassion logs with other tools, try define normal info.
Atleast System info ( Win version, x86 or x64 ) , installed drivers version. Normally that enough to define problem.
If check over search there is enough examples of such normal request.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 06-19-2016, 10:59   #7 (permalink)
nongmobile's Avatar
Member: 716581
Thanks Meter: 734
I CAN SHOW YOU
http://www.youtube.com/watch?v=uMvbcWNX6W0
The Following User Says Thank You to nongmobile For This Useful Post:
Old 06-19-2016, 11:01   #8 (permalink)
nongmobile's Avatar
Member: 716581
Thanks Meter: 734
JayDi @ Bad luck then. There is nothing to fix.
Old 06-19-2016, 11:15   #9 (permalink)
Member: 1043909
Thanks Meter: 50,169
@nongmobile
You have selected wrong way to ask for a help.
If you have a problem with CM2 - just explain a problem in details, our supporters always ready to help.
But if you come here with other products advertizing - you are in wrong place.
Please think well next time before advertize something here.
Thread closed.
Thank you for your kind cooperation and understanding !!
Page generated in 0.33315 seconds with 7 queries
