02-17-2015, 15:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | read flash from HTC Desire 310 failed Start at : [17.02.2015 / 16:04:04] Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x3 Probably - "Secure Boot" or "BootLoader Locked" phone Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Any idea? |
02-17-2015, 16:24 | #7 (permalink) |
Member: 2157664 Status: Offline Thanks Meter: 43 | same error with secure emmc Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending Error : DA init Failed! Error code : 0x3 Probably - "Secure Boot" or "BootLoader Locked" phone Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
02-17-2015, 16:29 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I need to know - is it enough secure mode, or I will be need buy such phone and implement all for this. It have very high cost in my region, so, not see reason to buy this one, if all will work normally with current version. @decodari , thanks. Got it. 1-2 days to find sample and 1 need to make all for it. |
02-17-2015, 17:18 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Yeah, I remember about that. Will find sample and implement support for HTC 310 and later - for HTC 616. |
02-18-2015, 07:03 | #11 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | You can use MTK droid tools to backup ( rooted ) phone ... The main problem here is to WRITE HTC Desire 310 ... probably will end with dead unit, due to secure status. Same issue and with ZTE Grand X Pro ect ... |
02-18-2015, 07:46 | #12 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I will try make it even on secured phones , not a big problem. Need just sample on hands. Root and rest - not a way Probably - will be enough BL unlock , and relock after. Will figure out what way exactly in few near days. |
02-18-2015, 10:17 | #14 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Code: fastboot oem unlock | |
