Old 06-03-2011, 12:05   #1 (permalink)
Member: 998896
Thanks Meter: 15
Red face read full flash for no lincse to prdous
COM16 [Serial2] selected
module v3.31
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read flash
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot Off
chip: 0001:4903:0003
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
slowest
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
warning: wrong cs at 0x00010318, retry...
error: too many retries during read operation
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.K01_KENX INDA_DM_ST32T3_AA_V18.BIN
project-id: K01_KENXINDA_DM_ST32T3_AA_V18, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
error: wrong answer: 79
error: wrong answer: 00 : wrong answer after chip id request
error: wrong answer: FF : wrong answer after chip cfi request
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
error: wrong answer: 0B
error: connection lost
Finished, time used: 1 min 24 sec
Remove/Install battery now ! plz halp me...
Old 06-03-2011, 12:51   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Which interface are you using for pin finding?
In your case phone connection was lost so it got disconnected.
Wr.
Old 06-03-2011, 20:40   #3 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
use rx tx,tp cables direct with infinity box and post result
Old 06-04-2011, 07:40   #4 (permalink)
Member: 998896
Thanks Meter: 15
Wink interfase
Wr.
i m using dragon for interfase with infinty chinese mircale v 3.31
Old 06-04-2011, 16:32   #5 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Well I knew that, but just wanted to confirm! Now try with Infinity pinfinder or Spiderman or direct rx-tx on phone and post result.
Wr.
Old 06-04-2011, 21:19   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
some communication problems...can be caused by bad com port drivers too.
if this box uses prolific usb-to-com converter- try to use driver from our support site
Old 06-05-2011, 12:49   #7 (permalink)
javedsf's Avatar
Member: 811013
Sonork: 03468717163
Thanks Meter: 744
ffs/eeprom chip: 00
hloo
Hardware prblam flsha chip not workes
Old 06-15-2011, 20:00   #8 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
sure set have a hardware problem may be water damage
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.23367 seconds with 9 queries
