05-10-2015, 07:01 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | read info failed in Micromax A37 Code: Wait for phone... Phone found! [ 254 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DRAM not initializewd , configure DRAM Settings DA Sent. Configure setting now ... DA start Failed! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:02:10 Reconnect Power/Cable! Write flash failed in both bin & scatter Load File Bad file detected! in bin i m giving backup file it is not accepting. |
05-10-2015, 07:31 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
2 clue u have already to solve your problem by self Code: set start in recovery mode Code: Preloader Status : Not active (Erased) it means side key short ,don't press any key , read info again without press any key ,and with battery , | |
The Following 2 Users Say Thank You to pradeep_kus For This Useful Post: |
