Old 03-11-2016, 12:52   #1 (permalink)
Member: 584832
Sonork: 100.1601217
Thanks Meter: 35
reading back up error..
whats wrong with this..
it always happen when i do back up..help
Operation : Read Flash [ v1.43 ]
Wait for phone...
Phone found! [ 109 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 11010030303447393051CEE4F823C0C9
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 09G40
[eMMC] : FLASH_CID : 11010030303447393051CEE4F823C0C9
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : DFB71B8B04C13D1B480250BCD990AA09
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Brand : Starmobile
ProdName : Up
ProdModel : UP
Device : b3475
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : B3475_DB34751_STARMOBILE-UP_L105
[Read Ok] : preloader_b3475.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : EBR2
[Read Ok] : test.img
#4338 : Data CRC Error : 7C9A , 7E0E
Error while reading block! Something went wrong
Read error
Operation Failed
Elapsed: 00:01:41
Reconnect Power/Cable!
Old 03-11-2016, 13:19   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
It's due to loose/bad connection. Use small good cable to direct usb port from pc back.
Br.
Infinity Box Support Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 03-11-2016, 13:25   #3 (permalink)
Member: 584832
Sonork: 100.1601217
Thanks Meter: 35
but why in other box its ok..same cable and same usb port..
Old 03-11-2016, 15:08   #4 (permalink)
hungsun_mobile's Avatar
Member: 723166
Sonork: 100.1590944
Thanks Meter: 129
infinity box very bad mtk 6582
Old 03-11-2016, 17:18   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Bad luck. Then you can't service that phone with CM2.
Yes. It very bad.
Page generated in 0.15862 seconds with 9 queries
