08-04-2015, 09:21 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Reading Full Flash Problem.. i m trying to read full flash software always gives fail.. i tried many devices and same error.. is this pc or comminication pb or software..? Code: Operation : Read Flash [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447393010958E423DA0D5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 09G40 [eMMC] : FLASH_CID : 11010030303447393010958E423DA0D5 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... #19440 : Data CRC Error : 3CC4 , 0000 Read error :( Operation Failed Elapsed: 00:04:06 Reconnect Power/Cable! |
08-04-2015, 12:41 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Need some info about it config : Which type - x86/x64 OS, CPU, RAM , USB 3.0 port present or not. First need try : Clean system from old SW, which can acess to ports or e.t.c. - like phone managers and rest same things. Or at least - off them, while you working with MTK. After - re-install drivers. Try use short USB cable, no any hubs. Also try other USB ports. Most times it enough. I can improve even fr such systems - but need to have it, test on it and check all things. It not possible remotely. |
