02-06-2017, 09:39 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Around GSM World
Member: 17684 Status: Offline Sonork: 100.1612623 Thanks Meter: 43 | redmi 3s,mi 5 cant be detect by soft 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! please help thanks |
02-06-2017, 10:02 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | And does other Qualcomm mobiles connect with CM2? Please install the drivers from the support. Akai you may require the deep flash cable to force edl mode.. |
02-06-2017, 10:14 | #4 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Install Emergency drivers how to install plz check here http://forum.gsmhosting.com/vbb/f296...video-2160627/ |
02-06-2017, 13:57 | #5 (permalink) |
Member: 17684 Status: Offline Sonork: 100.1612623 Thanks Meter: 43 | 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... thanks for help after driver installation device found and stuck initialize |
02-06-2017, 14:02 | #6 (permalink) | |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
