06-30-2017, 09:21 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: alger
Member: 2304080 Status: Offline Thanks Meter: 43 | Infinity Chinese Miracle-2 SPD/Spreadtrum v1.27 - SC773x Android 7 and FP Forensic === v1.27 === Infinity Chinese Miracle-2 SPD/Spreadtrum v1.27 - SC773x Android 7 and FP Forensic SP Platform: Activated SC773x Android 7 support Identify (service/boot) Read firmware ( SC/PAC ) Write Firmware ( SC/PAC ) Reset Settings/Format FS Reset FRP Flash erase NVM operations: Read, Write, Clear, Fix BB Repair Security (Normal and Flash Mode) SP Unlock eMMC test HW info read/write - Service operations improved FRP reset improved - Firmware reader updated New types supported FP Platform: - Main Revised bootloader package Booting issues on some models should be fixed - Unique UserData fatures activted! SC6500, SC6530, SC6531: Activated Direct PhoneBook recovery/extraction! Automatic detection of different phonebook types Support recovery for deleted/changed records ! It's possible to make recovery for device with ANY state as soon as it can be connected to PC ( except Format FS / Dump reflash ) SC653x Samsung: Revised PhoneBook recovery/extraction Support recovery for deleted/changed records ! - Other Some bugfixes and improvements at all FlashLoader package updated http://server1.infinity-box.com/down...M2SPD_v1.27.7z |
The Following 10 Users Say Thank You to baryt For This Useful Post: |
06-30-2017, 09:47 | #2 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | @baryt. Forget about spd6820 every year can found one of them Lets team work on new stuff like this |
The Following 2 Users Say Thank You to sky73 For This Useful Post: |
06-30-2017, 10:01 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Data recovery examples : Code: Operation : Read PhoneBook [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Check data ... Reading UDA ... Process can take some time, please, wait Records Found : 151 Saved to : C:\InfinityBox\CM2SPD\phdata\6531_fly_PhoneBook.csv Read Done! Elapsed: 00:00:13 Reconnect Power/Cable! Code: Operation : Read PhoneBook [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data ... Reading UDA ... Process can take some time, please, wait Records Found : 155 Saved to : C:\InfinityBox\CM2SPD\phdata\6531_dexp_PhoneBook.csv Read Done! Elapsed: 00:00:09 Reconnect Power/Cable! That allow recovery deleted data, modified and etc. cases as well. But remember - count of DELETED data extraction DEPEND ONLY ON TIME OF USE PHONE AFTER DATA DELETING! More time - less data. i.e. - week-few using will allow extract 80-100% . month - 40-90%, more - depend on luck. |
The Following 7 Users Say Thank You to JayDi For This Useful Post: |
06-30-2017, 10:04 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I had tested near 50 dumps, found over net for desribed CPU's, but there can be some vendor-specific types, which containt multi-record and other structures, so if you get device and extraction fail, or data damaged - send us dumps and we will add those types. |
The Following 8 Users Say Thank You to JayDi For This Useful Post: |
06-30-2017, 10:39 | #5 (permalink) |
No Life Poster Join Date: Nov 2016 Location: iran tehran 021
Member: 2643931 Status: Offline Sonork: ****** Thanks Meter: 225 | sc6810 6820 pleaseeeeeeeeeeee adddddddddddddddd I said so much that I was hurt |
The Following User Says Thank You to afghanistanmob For This Useful Post: |
06-30-2017, 11:19 | #6 (permalink) |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Infinity Team If Possible Please Add next update in SPD6820/8810 Read/Write/Unlock/Formate |
The Following 2 Users Say Thank You to >>Gsmmilon>> For This Useful Post: |
06-30-2017, 11:36 | #7 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Earth
Member: 593876 Status: Offline Thanks Meter: 302 | card firmware ver should be update Quote:
Am i Right? Jaydi Sir!! | |
The Following User Says Thank You to mcclinic For This Useful Post: |
06-30-2017, 12:02 | #9 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
The Following 13 Users Say Thank You to JayDi For This Useful Post: |
06-30-2017, 12:10 | #11 (permalink) | |
Some time agou users had cry about need rename CM2/Infinity to MTK tool, now they cry about why there is no MTK There is near 58 versions of MTK module, and just 14 of QLM, 2 of RKT, 6 of RDA, 27 of SPD, 4 of LGS and one of AST. Left just 4 for parity | |
The Following 9 Users Say Thank You to JayDi For This Useful Post: |
06-30-2017, 13:30 | #14 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
online photo storage Code: Start at : [30/06/2017 / 15:07:12] Operation : Read PhoneBook [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data ... Reading UDA ... Process can take some time, please, wait No any record found! Looks Like PhoneBook on SIM or phone after Format FS Elapsed: 00:00:11 Reconnect Power/Cable! Finish at : [30/06/2017 / 15:07:24] Start at : [30/06/2017 / 15:07:55] Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 B20<Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : GD25LQ32 Model Name : ADMET 5700 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32__GD25LQ32-ADMET 5700.bin Done! Elapsed: 00:01:33 Reconnect Power/Cable! Finish at : [30/06/2017 / 15:09:28] https://forum.gsmhosting.com/vbb/****************************/?7gry7laqk9f1x1g | |
The Following User Says Thank You to Kirumira For This Useful Post: |
06-30-2017, 14:33 | #15 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Code: Operation : Read PhoneBook [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 ÿB ÔBoot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0018 0000 [0] Flash VEN : GigaDevice , GD25LQ128 [0] Flash CAP : 01000000 Check data ... Reading UDA ... Process can take some time, please, wait ========================= Start ========================= online photo storage Code: ========================================================= Card found: S/N : xxxc, v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Start at : [30/06/2017 / 15:59:23] Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 ?µ<Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0018 0000 [0] Flash VEN : GigaDevice , GD25LQ128 [0] Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_12C.W13.04.14_Debug it2560_G230B_128X64_320X240BAR_EnFrPoBaSwHaArSoAmOrTi Project : IT2560-G230B-EnFrPoBaSwHaArSoAmOrTi_20140912 HWInfo : fp6531_bar Compile : 09-12-2014 19:48:14 Set FileInfo : Model Vendor : GD25LQ128 Model Name : ITEL 2560 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MOCOR_12C.W13.04.14_Debug_it2560_G230B_128X64_320X240BAR_EnFrPoBaSwHaArSoAmOrTi_09122014194814__GD25LQ128-ITEL 2560.bin Done! Elapsed: 00:02:07 Reconnect Power/Cable! https://forum.gsmhosting.com/vbb/****************************/?qegeanqp28kpff2 Last edited by Kirumira; 06-30-2017 at 14:42. |
