Old 06-25-2018, 14:12   #1 (permalink)
silhouette's Avatar
Member: 52597
Thanks Meter: 275
REDMI 5 MDG1 after MI account reset cannot detect sim/s
IMEIs are ok, also did security OP wipe security operation (though it wasn't necessary)
What could be cause of sims not detected? Memory card detects ok
Old 06-25-2018, 16:41   #2 (permalink)
Member: 1436243
Thanks Meter: 99
check baseband info, or maybe you need try with another simcard
The Following User Says Thank You to mifluvcute For This Useful Post:
Old 06-25-2018, 16:57   #3 (permalink)
silhouette's Avatar
Member: 52597
Thanks Meter: 275
Right, IMEI was showing briefly
Now IMEIs and baseband status 'unknown'
Infinity supports IMEI baseband repair for this model?
Old 06-25-2018, 17:16   #4 (permalink)
Member: 2677842
Sonork: 10.154544
Thanks Meter: 35
write persist from flash file will resolve issue..........
The Following User Says Thank You to icloudboss2016 For This Useful Post:
Old 06-25-2018, 17:28   #5 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Arrow
right, imei was showing briefly
now imeis and baseband status 'unknown'
infinity supports imei baseband repair for this model?
for best result flash the fone
all will be ok
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 06-26-2018, 16:17   #6 (permalink)
silhouette's Avatar
Member: 52597
Thanks Meter: 275
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Loading firmware ...
Loading 1 program definition file(s) ...
Load Ok!
Operation : Flash [ v1.16 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 625 [MSM8953]
ID_BLOCK_S : 00AA03A5
ID_BLOCK_L : B9E66541EBFA2E710054E4A337A75778
ID_BLOCK_L : 7282F85F9EB9A9817EC90AFD7AEC386D
Pickup loader from firmware package
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE63MB
Boot Ok!
Flash Chain : 52
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : devcfg.mbn
Flashing : adspso.bin
Flashing : splash.img
Flashing : emmc_appsboot.mbn
Flashing : boot.img
Flashing : recovery.img
Flashing : system.img
Flashing : cache.img
Flashing : lksecapp.mbn
Flashing : cmnlib.mbn
Flashing : cmnlib64.mbn
Flashing : keymaster.mbn
Flashing : cust.img
Flashing : userdata.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Applying patches for storage # 0
Records : 26
Patch sequence completed!
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:03:17
Reconnect Power/Cable!
Load Ok!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Flash Chain : 52
Flashing now
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : boot.img
Flashing : cust.img
Records : 26
Flashing done!
Done!
Elapsed: 00:03:17
Flash write ok, also only persist flashed
Still Invalid device ID 'unable to get imei'
Old 06-26-2018, 16:56   #7 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
Load Ok!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Flash Chain : 52
Flashing now
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : boot.img
Flashing : cust.img
Records : 26
Flashing done!
Done!
Elapsed: 00:03:17
Load Ok!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Flash Chain : 52
Flashing now
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : boot.img
Flashing : cust.img
Records : 26
Flashing done!
Done!
Elapsed: 00:03:17
enable diag with *#*#717717#*#*
make sure driver installed
repair imei with cm2qlm
reboot
write a qcn file
factory reset
you will get imei and signal
Old 06-26-2018, 18:46   #8 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
In some cases also require use older FW version, because diag port commands are closed in newer MIUI versions.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 06-26-2018, 19:36   #9 (permalink)
silhouette's Avatar
Member: 52597
Thanks Meter: 275
reboot
write a qcn file
factory reset
Does this require unlocked bootloader? *#*#717717#*#* code does not work
Old 06-26-2018, 20:06   #10 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
need reset security you did it allready
so just use code
The Following User Says Thank You to sky73 For This Useful Post:
Old 06-27-2018, 12:23   #11 (permalink)
silhouette's Avatar
Member: 52597
Thanks Meter: 275
so just use code
I have version MIUI global stable 9.2.3.0 and diag code does not work
Will be grateful for any video link or success log for qualcomm imei repair
Also full flashed different roms via edl mode
Old 06-27-2018, 12:30   #12 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
i just try on miui 9.5 and you right its not work
try downgrade to older miui
Old 06-27-2018, 12:48   #13 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
here log operation
http://forum.gsmhosting.com/vbb/13184677-post4.html
also try unlock bootloader- root and check enable diag with adb and root
Old 06-27-2018, 15:38   #14 (permalink)
silhouette's Avatar
Member: 52597
Thanks Meter: 275
here log operation
I got Diag Mode to work with *#*#13491#*#*, read qcn successfully
I cannot see IMEI write option in CM2QLM software
The Following User Says Thank You to silhouette For This Useful Post:
Old 06-27-2018, 15:50   #15 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
put uk.off file on cm2qlm folder
Page generated in 0.22756 seconds with 8 queries
