11-12-2018, 15:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Bulgaria Smolyan
Member: 203747 Status: Offline Thanks Meter: 94 | REDMI 6 pro cant boot 1 try to boot it VOL+VOL- no luck 2 then try to boot it via EDL no luck again here is the log Connect device in fastboot mode ... Connect Ok! Trying set EDL mode ... If device not reboot in EDL - use KEYS combination / EDL cable / TP Operation finished! any help pls |
11-12-2018, 17:43 | #2 (permalink) |
Member: 203747 Status: Offline Thanks Meter: 94 | hi so i try using TP but still cant boot it need help here is the log via TP Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : AAEF2342 ID_BLOCK_L : DC850624889F4114BD3781C458CA3205 ID_BLOCK_L : B9473D945B7214CAB514CDB8C737E3A6 Use CM2 Internal Loader FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! |
