02-17-2017, 09:12 | #1 (permalink) |
Freak Poster Join Date: Apr 2013
Member: 1913632 Status: Offline Thanks Meter: 233 | redmi note 3 users lock reset ok but read flash some thing wronge Connect Ok! Trying set EDL mode ... If device not reboot in EDL - use KEYS combination/EDL cable/TP Operation finished! Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 0427A302 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 1C45C6E4485F81D4FDF74104980AF2C5 ID_BLOCK_L : F10F65DC133A2C02FD4C8580FF6FBBEE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 032G34 Boot Ok! Brand : Xiaomi ProdName : kenzo ProdModel : Redmi Note 3 Device : kenzo AndroidVer: 5.1.1 Manufact. : Xiaomi QLMxCPU : MSM8952 DevInfo : MSM8952__Xiaomi__Xiaomi__ANDR_v5.1.1__Redmi_Note_3 __kenzo__kenzo Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : adspso.bin [Read Ok] : ddr.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : splash.img [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : mdtp.img [Read Ok] : cust.img Error : Failed to convert data! Erased/Damaged device??? Send log and report.log to support! Include device info also! Reconnect Power/Cable! Connect device in fastboot mode ... Connect Ok! Trying set EDL mode ... If device not reboot in EDL - use KEYS combination/EDL cable/TP Operation finished! Operation : Reset UserLocks [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 0427A302 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 1C45C6E4485F81D4FDF74104980AF2C5 ID_BLOCK_L : F10F65DC133A2C02FD4C8580FF6FBBEE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 032G34 Boot Ok! Direct access : Ok! Processing step #1 Processing step #2 Processing step #3 Processing step #4 Processing step #5 Processing step #6 Processing step #7 UserLocks reset passed! 1. Power On phone, wait 30-50 second, press and hold PowerOn button until device restart! 2. To disable/remove fingerprints enter in Settings -> FingerPrint, set any password, remove fingerprints 3. In some cases require reboot phone twice or wait up to 5 minutes! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to pravakar333 For This Useful Post: |
