08-03-2018, 16:15 | #1 (permalink) | |
Moderator Join Date: Apr 2011 Location: B.A.N.G.L.A.D.E.S.H Age: 34
Member: 1566464 Status: Offline Sonork: 100.1611207 Thanks Meter: 929 | Redmi Note 4x (frp) google account done cm2 World first then hold vol+ then connect phone then enjoy Quote:
__________________ __________________ Always Follow the Rules Best Regards, Sayed Tarik | |
The Following 4 Users Say Thank You to sayed tarik For This Useful Post: |
01-11-2019, 09:24 | #3 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Done! Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 435 [MSM8940] ID_BLOCK_S : 8039F55A ID_BLOCK_L : F4BD2E0CB0B7793C552FB9EC60D22A2D ID_BLOCK_L : 03FD772EE1C8DA10CF5E7B6E097DA91C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x45 , VENDOR : SANDISK , NAME : DL2032 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to Shani3 For This Useful Post: |
