01-21-2017, 15:53 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Tamilnadu Age: 46
Member: 740523 Status: Offline Thanks Meter: 93 | redmi note3 mi account remove Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 00ABF8A8 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : A6E3605EEEE52B8E0759E75E32A0587F ID_BLOCK_L : 7583F9589FBEA88671C809FC7BF33F62 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 032G34 Boot Ok! MIAccount reset passed! Normal reset : > Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings" > PowerOn device and use. IF Device stuck on black screen with cable - use another FMT > Not all devices supported yet! (tested on Hydrogen,Land,Redmi2) Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 7 Users Say Thank You to .::VijayAnand::. For This Useful Post: |
01-21-2017, 19:38 | #2 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | really perfect box in his own class, no tension to stuck any tab, we get hundred present success result, i also done note 3 , which again lock when i connect wifi, i tried all boxes, but in last i get success with infinity cm2 qualcomm module, since due to busy schedule i dont post screen shot at that time, but i really admire infinity team all work. |
The Following User Says Thank You to galaxycompue For This Useful Post: |
01-22-2017, 11:48 | #3 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | mi redmi note 3 account remove in single click- Card found : 94FBD840 , v0134 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 00E93A92 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 8CF55674F8CF31646D67F1B4289A6255 ID_BLOCK_L : B34D279E51786AC0BF0ECBBEB92DF9AC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 032G34 Boot Ok! MIAccount reset passed! Normal reset : > Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings" > PowerOn device and use. IF Device stuck on black screen with cable - use another FMT > Not all devices supported yet! (tested on Hydrogen,Land,Redmi2) Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
04-02-2017, 08:13 | #7 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1915510 Status: Offline Thanks Meter: 19 | Operation : Reset Settings [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 425 [MSM8917] ID_BLOCK_S : 00798D30 ID_BLOCK_I : 000560E1 ID_BLOCK_L : 2E6BF8D6666D53068FC16FD64A38C0F7 ID_BLOCK_L : 43BDB76EA1889A500F9E3B2E49BD695C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! MIAccount reset passed! Normal reset : > Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings" > PowerOn device and use. IF Device stuck on black screen with cable - use another FMT > Not all devices supported yet! (tested on Hydrogen,Land,Redmi2) Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
04-02-2017, 16:58 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Way is downgrade to MIUI 7.x and reset acc. Then enter own/new acc. Upgrade over WiFi , out from acc. |
