10-08-2018, 08:00 | #1 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Redmi Y2 Mi account remove done by CM2 Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : FFB012AC ID_BLOCK_L : A2EF7C5AE2E1D78A0B5DEB5ACEBC5C73 ID_BLOCK_L : 7884FE5598B3538B74D70CF780F62267 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x13 , VENDOR : NOT_IN_BASE , NAME : S0J9B7 Boot Ok! Brand : xiaomi ProdName : ysl ProdModel : Redmi S2 Device : ysl AndroidVer: 8.1.0 Manufact. : Xiaomi SysPatch : OPM1.171019.011 DevComTime: 9/18/2018 12:43:38 PM USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:26 Code: Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : FFB012AC ID_BLOCK_L : A2EF7C5AE2E1D78A0B5DEB5ACEBC5C73 ID_BLOCK_L : 7884FE5598B3538B74D70CF780F62267 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x13 , VENDOR : NOT_IN_BASE , NAME : S0J9B7 Boot Ok! Flash Chain : 60 Flashing now Flashing : config.bin Flashing : persist.img Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:00:03 Reconnect Power/Cable! |
The Following 13 Users Say Thank You to kamal_singla For This Useful Post: |
10-08-2018, 13:39 | #9 (permalink) |
Member: 2211790 Status: Offline Thanks Meter: 5,118 | |
The Following 17 Users Say Thank You to kamal_singla For This Useful Post: |
10-08-2018, 22:41 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
01-08-2019, 18:04 | #14 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Romania, Fagaras Age: 46
Member: 34379 Status: Offline Thanks Meter: 101 | Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 08566FB8 ID_BLOCK_L : 561370AE1E15DB9E3749174EC2B0488F ID_BLOCK_L : 1EDE9433C2D5FD2D2ABD56512E984439 Use CM2 Internal Loader FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! I have this error when connect same phone. Any help please. |
02-05-2019, 19:49 | #15 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Chin
Member: 1531030 Status: Offline Sonork: Yahoo_Akm Thanks Meter: 118 | Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : AC248F10 ID_BLOCK_L : 0E4BD8F6464DB3E6EFE14F36AA18E0D7 ID_BLOCK_L : EC0862C114272FFFF8438083FC6AB6EB Use CM2 Internal Loader FH_LOAD_CODE : 15 ERROR : Loader send failed! ....................... ? HINT : Check cable, connection and drivers! Reconnect Power/Cable! Teem Plz. Halp |
