09-09-2015, 10:56 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Reeder P8C / Star UleFone U5 Full Flash or NV Backup..? especially i need NVbackup.. device is working but no lcd after full erase the device.. Code: Start at : [03.09.2015 / 12:26:32] Operation : Check / Read Info [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3038470F323732348179 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G80ME [eMMC] : FLASH_CID : 45010053454D3038470F323732348179 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : reeder ProdName : reeder_p8c ProdModel : reeder_P8C Device : 109v82_gq3016_reeder AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.11 Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
09-09-2015, 11:16 | #3 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | let me explain device history.. it was only customization screen and not goes on the normal system..(because of OTA update) after that i readed firmware -not full- then format the device..nothing changed..after that i flashed the device which i take the backup with selecting 3 options..flash erase,verify, and repartition.. after that lcd is blank but device is working.. as i see on the log software takes the backup.. but i m not sure.. can u chcek it my nv file..? Code: Backup : not found, will read now ... Format : Cache Only Format CACHE block Format block Ok! Done! Elapsed: 00:00:46 Reconnect Power/Cable! Backup : Already exist FMT Mode set to : 10 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! |
09-09-2015, 13:25 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Yes, it have dynamic HW settings. Btw - CM2 should say about error read fw, if it read and says about no error - that mean HWsettings was already erased. Need alive phone now and readout fw from it. |
09-10-2015, 11:23 | #9 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | just refreshing the thread.. http://store2.up-00.com/2015-08/1439629766972.png http://store2.up-00.com/2015-08/1439629766811.png |
09-10-2015, 14:18 | #11 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
Code: Card found: S/N 3EB4:0129 Chinese Miracle II [MTK module] v 1.29 Operation : Check / Read Info [ v1.29 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3038470F323732348179 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G80ME [eMMC] : FLASH_CID : 45010053454D3038470F323732348179 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : reeder ProdName : reeder_p8c ProdModel : reeder_P8C Device : 109v82_gq3016_reeder AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.11 MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V35_P8_1_wg_n Done! Elapsed: 00:00:15 Reconnect Power/Cable! | |
09-10-2015, 14:23 | #12 (permalink) | |
when i choose the scatter file software gives all details.. | |
09-12-2015, 11:18 | #15 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Great. Please, if phone still on hands - make factory FW reading and let me know result. If it will ask pack data and send to support - upload it and send me link in pm. |
