04-26-2016, 16:34 | #5 (permalink) |
No Life Poster Join Date: Mar 2010 Location: pakistan jhelum
Member: 1261180 Status: Offline Sonork: 100.1590645 Thanks Meter: 97 | here is log Card found: S/N : 53491E3F , v0130 Chinese Miracle II [SPD module] v 1.16 Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 78 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 183 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 78 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : QMobile_T480 Model Brand : QMobile Model Device: scx35_sp7731gea AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA CompileDate : 8/31/2015 9:34:25 AM Project Ver : QMobile_T480_MP_31_08 Model Ext : T480 ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:18 Reconnect Power/Cable! |
04-27-2016, 07:51 | #7 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2119608 Status: Offline Thanks Meter: 41 | Model Name : QMobile_T480 Model Brand : QMobile Model Device: scx35_sp7731gea AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA CompileDate : 31-Aug-15 9:34:25 AM Project Ver : QMobile_T480_MP_31_08 Model Ext : T480 i flashed the same model T480 and it worked for me but before somedays i flash the same file to other 2 T480 but those were hang on logo |
04-27-2016, 08:44 | #9 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | file 1 Code: Loading : QMobile_T480_W822_M03_S08_150831.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobile_T480_W822_M03_S08_150831 FastCheck : 0x00440DFE61 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : Logo1.bmp File : cache.img File : u-boot.bin File : SC77xx.xml Load Ok! Code: Loading : QMobile_T480_W822_M03_S06_150629.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobile_T480_W822_M03_S06_150629 FastCheck : 0x00440DBD89 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : charge_logo.bmp File : cache.img File : u-boot.bin File : SC77xx.xml Load Ok! |
The Following User Says Thank You to asad_nomy7 For This Useful Post: |
04-27-2016, 08:49 | #10 (permalink) | |
Member: 1261180 Status: Offline Sonork: 100.1590645 Thanks Meter: 97 | Quote:
04-27-2016, 08:50 | #11 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | So, that mean for new revisions set Project Ver : QMobile_T480_MP_31_08 should be like : Project Ver : QMobile_T480_MP_29_06 |
