07-30-2011, 20:55 | #1 (permalink) |
Insane Poster Join Date: Dec 2007
Member: 660421 Status: Offline Thanks Meter: 26 | Help, Can't unlock network MT6225_lock version: 59535F53 can't unlock operator/provider on G-Von Model 620 here is the log, SP Unlock - standard method Code: COM95 [Serial3] selected module v3.98 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7B03:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.98, database date: 25.07.2011): ET25_GEMINI_PCB01_GPRS_MT6225_S00.YS_S25_05_V06.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: ET25_GEMINI_PCB01_GPRS_MT6225_S00.YS_S25_05_V06.BIN project-id: YS_S25_05_V06, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent detecting ffs/eeprom structure pass 1... ........................... ffs/eeprom: detect std location pass #1... ................................................... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: ET25_GEMINI_PCB01_GPRS_MT6225_S00.YS_S25_05_V06__ffs... file saved: C:\InfinityBox\MModule\ET25_GEMINI_PCB01_GPRS_MT6225_S00.YS_S25_05_V06__ffs_20110731-020909.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: EC257E25082501:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 29 sec Remove/Install battery now ! try with standard fast method, Code: COM95 [Serial3] selected module v3.98 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7B03:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.98, database date: 25.07.2011): ET25_GEMINI_PCB01_GPRS_MT6225_S00.YS_S25_05_V06.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: ET25_GEMINI_PCB01_GPRS_MT6225_S00.YS_S25_05_V06.BIN project-id: YS_S25_05_V06, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent detecting ffs/eeprom structure pass 1... ........................... ffs/eeprom: detect std location pass #1... ................................................... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Fail Finished, time used: 1 min 36 sec Remove/Install battery now ! Code: COM95 [Serial3] selected module v3.98 Action: "sp-unlock" unlock method: smart fast Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7B03:000D status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: YS_S25_05_V06 Version: ET25_GEMINI_HW ==================== New firmware found (v.3.98, database date: 25.07.2011): YS_S25_05_V06 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 5 11 done 67 byte(s) read imei: 35610610255228 connection Ok detecting structure #1... 1 5 8 9 10 12 13 14 done 178 byte(s) read reading data... reading data #2... building new data... writing data... detecting structure #3... error: can't read additional data reading data... 34 byte(s) read building new data... warning: unknown lock version: 59535F53 error: data is invalid Finished, time used: 17 sec Remove/Install battery now ! would you please to cek the firmware, i have full flash backup and eeprom up here : G-Von Model620_MT6225_sim1_Locked network.rar - 4shared.com - online file sharing and storage - download thank you wbr, madshark |
07-30-2011, 22:25 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Thanks, file downloaded. Do you know, what operator this phone is locked ? Is it really network/provider lock or is it just user code ? Last edited by YellowBoss; 07-30-2011 at 22:34. |
07-30-2011, 22:49 | #3 (permalink) |
Member: 660421 Status: Offline Thanks Meter: 26 | hello, this phone working fine, with 2slot GSM on but its locked sim1 by provider/operator telkomsel indonesia thank you for your fast reply and i'm waiting for the next step wbr, madshark |
07-31-2011, 01:36 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, please, post here full text from back label (without imei) and pinout. We will try to release updated software for this model unlock as soon as possible. |
07-31-2011, 17:08 | #5 (permalink) |
Member: 660421 Status: Offline Thanks Meter: 26 | Hello, nothing else on back label, there's only typed "G-Von Model620" and "imei serial Number" about pinout, here is in picture thankyou for your help wbr, madshark |
The Following User Says Thank You to madshark96 For This Useful Post: |
09-09-2011, 13:51 | #6 (permalink) |
Member: 660421 Status: Offline Thanks Meter: 26 | Hello, Infinity Team i have another cellphone here, MT6225 Cpu Chipset its a same board with G-Von 620,.. same Pinout and same Locked to Operator Telkomsel i try to unlock SPLock, but still not lucky : building new data... warning: unknown lock version: 59535F53 error: data is invalid Becouse of this firmware missing in Support, so upload here Fullflash backup and the Log File: TiPhone T30_MT6225 Locked Telkomsel Indonesia.rar - 4shared.com - online file sharing and storage - download I hope, My Great teams can releases as soon as new of software with features to unlock this model Thank you, Wbr. madshark |
02-21-2012, 20:09 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, If somebody have this phone on hands, you can try this: 1. download special unlock file from support area 2. make full flash backup 3. flash phone with special file Let's see results. |
