09-25-2017, 13:01 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Slovakia BA Age: 51
Member: 25110 Status: Offline Thanks Meter: 79 | remi note 3 QLC - restarting after remove find my device app After I tried removed find my dev App and now phone is restatring in 5min intervals. Do you have some flash file original or infinity to flash my phone of fix some other way? I tried it with XiaoMiFlash tool but no succes. thank you for help. |
09-25-2017, 14:40 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Format with Forced Fix/Repair Data option and check result. If this not helps flash with latest version. Br. Infinity Box Team. |
09-25-2017, 14:53 | #3 (permalink) |
Member: 25110 Status: Offline Thanks Meter: 79 | I have latest version, can not flash with the app, because phone not started, can not flash by fastboot, because flashing is locked. Can not unlock flash with ifinity, some trick? Or official way exist only. |
09-25-2017, 15:24 | #5 (permalink) |
Member: 25110 Status: Offline Thanks Meter: 79 | Ok, edl mode can get. but which flasher can flash in this mode original latest flash file? I infinity programm which file do I need select? partition.xml patch0.xml rawprogram0.xml or sahara.xml thank you |
09-25-2017, 16:11 | #7 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
You can select any, CM2QLM is automatic, it will detect and flash required files. Anyway about particular file from all that you posted rawprogram0.xml needs to be selected. Br. Infinity Box Team. | |
