01-20-2016, 18:30 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Spain
Member: 840762 Status: Offline Thanks Meter: 166 | remove factory reset protection in mtk acer iconia one 10 b3-a20? My customer has forgotten the gmail (only make gmail for startup tablet and not remember) Any solution for remove FRP? BR |
01-22-2016, 13:38 | #3 (permalink) | |
Member: 840762 Status: Offline Thanks Meter: 166 | This cpu (MT8163) not working with latest cm2mtk I think: Quote:
BR | |
01-22-2016, 14:36 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Wait until tomorrow ( maybe up to +1 day ). Right now I had add only NAND with MT8163. Will try add eMMC also. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
02-17-2016, 09:55 | #5 (permalink) | |
Member: 840762 Status: Offline Thanks Meter: 166 | Hi, Same proble with latest version, I try FRP reset: Quote:
02-17-2016, 11:41 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. It uses "Secure Boot" concept, or it have locked bootloader. As remember , those phones used own boot. Will try llok for such sample and check it. |
06-06-2016, 12:06 | #8 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
Acer Iconia B1-850 Tablet It Seems Too Be Locked Bootloader Device Code: Wait for phone... Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1616.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x97 NAND Flash : NOT INSTALLED eMMC Flash : 90014A484147326505071CC97457C2EF Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBC000000 DRAM_INIT_REQ_FAILED Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! Is There Any Help Possible ? Thanks Anticipation | |
09-30-2016, 09:23 | #12 (permalink) |
Insane Poster Join Date: Jul 2005 Age: 50
Member: 164076 Status: Offline Thanks Meter: 3 | Chinese Miracle II [MTK module] v 1.56 Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Format FileSystem [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! plz i'need help for this pb |
