Old 05-08-2018, 15:44   #1 (permalink)
Member: 1140831
Sonork: no
Thanks Meter: 232
frp error yuho h2 plz help (USBDL : Error init HSUSB!!!)
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019065324741441007055D4516D9
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x40000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A484147326505071044D916B25D
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0x73CC19F24381292FB53EC5994FB303E9
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:15
Reconnect Power/Cable!
no info reed
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Fatal error, buffer empty! Phone connection lost???
Done!
Elapsed: 00:00:13
Old 05-09-2018, 06:23   #2 (permalink)
Member: 1140831
Sonork: no
Thanks Meter: 232
plz help i need this set flash file if you help
Old 05-09-2018, 06:28   #3 (permalink)
Member: 1140831
Sonork: no
Thanks Meter: 232
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
INFO : max-download-size: 0x8000000
INFO : partition-size:flashinfo: 1000000
INFO : partition-type:flashinfo: raw data
INFO : partition-size:userdata: 32000000
INFO : partition-type:userdata: ext4
INFO : partition-size:cache: 19000000
INFO : partition-type:cache: ext4
INFO : partition-size:system: 100000000
INFO : partition-type:system: ext4
INFO : partition-size:metadata: 2480000
INFO : partition-type:metadata: raw data
INFO : partition-size:nvdata: 2000000
INFO : partition-type:nvdata: ext4
INFO : partition-size:frp: 100000
INFO : partition-type:frp: raw data
INFO : partition-size:tee2: 500000
INFO : partition-type:tee2: raw data
INFO : partition-size:tee1: 500000
INFO : partition-type:tee1: raw data
INFO : partition-size:keystore: 800000
INFO : partition-type:keystore: raw data
INFO : partition-size:secro: 600000
INFO : partition-type:secro: raw data
INFO : partition-sizeemkeystore: 200000
INFO : partition-typeemkeystore: raw data
INFO : partition-size:seccfg: 80000
INFO : partition-type:seccfg: raw data
INFO : partition-size:expdb: a00000
INFO : partition-type:expdb: raw data
INFO : partition-size:logo: 800000
INFO : partition-type:logo: raw data
INFO : partition-size:recovery: 1000000
INFO : partition-type:recovery: raw data
INFO : partition-size:boot: 1000000
INFO : partition-type:boot: raw data
INFO : partition-sizeara: 80000
INFO : partition-typeara: raw data
INFO : partition-size:lk: 100000
INFO : partition-type:lk: raw data
INFO : partition-sizerotect2: a00000
INFO : partition-typerotect2: ext4
INFO : partition-sizerotect1: a00000
INFO : partition-typerotect1: ext4
INFO : partition-size:nvram: 500000
INFO : partition-type:nvram: raw data
INFO : partition-sizeroinfo: 300000
INFO : partition-typeroinfo: raw data
INFO : partition-sizereloader: 40000
INFO : partition-typereloader: raw data
INFO : off-mode-charge: 1
INFO : warranty: yes
INFO : unlocked: no
INFO : secure: yes
INFO : kernel: lk
INFO : product: S103
INFO : version-preloader: 0.1.00
INFO : version: 0.5
INFO : Done!!
OEM : FAILunknown command
Old 05-09-2018, 06:32   #4 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:15
no info reed
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:13
seems connection lost or high speed drivers not installed
make sure battery power enough and check high speed drivers installed or not
Old 05-10-2018, 05:23   #5 (permalink)
Member: 1140831
Sonork: no
Thanks Meter: 232
any one help any idea
Page generated in 0.17560 seconds with 8 queries
