07-24-2017, 09:59 | #1 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1021269 Status: Offline Sonork: 100.1623820 Thanks Meter: 10 | Infinity-Box team ,plz check my log! Load File FileVersion : MT6755 Load File Ok Start at : [2017/7/23 / 18:03:44] Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : MT6755__OPPO__OPPO_A59m__A59m__A59__A59m_11_A.19_1 61209__Android_5.1.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D420723F2E027C3BF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xE0AE3C357B545CC21C43F4B6860623EB INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! USBDL : Init HSUSB Ok! ISPFF ID : 6755 , TARGET ID : 6755 Flash pre-erase disabled Write Flash now ... [ MCU ] : MT6755__OPPO__OPPO_A59m__A59m__A59__A59m_11_A.19_1 61209__Android_5.1.ispff Init Ok , Sending blocks ... Prepare failed Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:00:44 Reconnect Power/Cable! plz check,thx! |
07-24-2017, 12:19 | #4 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Quote:
make emmc read write test.. | |
