06-27-2008, 21:20 | #1 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | Report problem on mt6227 I just want to report, i'm using chineese miracle 2.48. my phone was restart with sim. my phone is got 2 flash chip, one is NOR and one is NAND. i cant read eeprom, fullflash, i only can read detail and format safe. the logs shown below. Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6227, E02 Hardware version: FIREBOLT_A Software version: D121_A122_1.07.0" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 352317002140954 Finished, time used: 42 sec Power off phone now ! Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled eeprom backup enabled, it may takes several minutes ! Action: read eeprom Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6227:8A02:8A01]... CPU: MT6227 high speed boot disabled chip: 0031:0DE3:01CE high speed disabled boot step size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 22 sec Remove/Install battery now ! Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6227:8A02:8A01]... CPU: MT6227 high speed boot disabled chip: 0031:0DE3:01CE high speed disabled boot step size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 21 sec Remove/Install battery now ! Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6227:8A02:8A01]... CPU: MT6227 high speed boot disabled chip: 0031:0DE3:01CE high speed disabled boot step size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 16 sec Remove/Install battery now ! Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6227:8A02:8A01]... CPU: MT6227 high speed boot disabled chip: 0031:0DE3:01CE Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.2 Version: D121_A122_1.07.0 Version: FIREBOLT_A detecting structure #2... done 60 byte(s) read imei: 35231700214095 connection Ok building list... done items to clear: 210 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs 142 of 210 items cleared building list... done 0 items remains Finished, time used: 178 sec Remove/Install battery now ! Read nand is successfully, sorry didnt show the log for read nand. but the problem is solved with format Safe. thanks to infinity team . and hope next update will fix mt6227 problem, thank you. |
06-28-2008, 09:37 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I don't think that bugs exist with MT6227. If you have connection problems try to set "boot step size" value to 02 ("settings" page) for more stable connection. |
SMS delivery report problem on P1i | satawn | Sony Ericsson | 0 | 10-07-2007 09:03 |
Problem on accessing MS Windo-based application on SEP900 | edapril23 | Sony Ericsson | 0 | 12-07-2004 10:17 |
probleme on read code on GD67 .... ? | Dworkin | Panasonic | 6 | 02-23-2004 20:44 |
Problem on T610 Error on GDFS | MicrostarGSM® | Cruiser Suite | 2 | 01-20-2004 12:19 |
Problem on turn-on s45 (now i!!) | kalavera pt | x1x to x45/x50 | 1 | 11-02-2002 16:56 |
