03-30-2018, 15:34 | #1 (permalink) |
Freak Poster Join Date: Nov 2017 Location: midrand
Member: 2783412 Status: Offline Sonork: 1680285 Thanks Meter: 226 | {request} azumi kirei a45d if any one have please share with me |
The Following 2 Users Say Thank You to choksi For This Useful Post: |
05-08-2018, 11:25 | #3 (permalink) |
Freak Poster Join Date: Apr 2016 Location: South Africa /Pakistan Age: 29
Member: 2555393 Status: Offline Thanks Meter: 268 | Azumi Kirei A45 D it's nand MT6570 (Dualcore 1,2Ghz) android 6.0 here is link check all about device Azumi Mobile |
05-08-2018, 11:33 | #4 (permalink) |
Member: 2555393 Status: Offline Thanks Meter: 268 | cm2 can't read info 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
The Following User Says Thank You to sajjad akram For This Useful Post: |
05-08-2018, 12:14 | #5 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
05-10-2018, 07:09 | #6 (permalink) |
Member: 2783412 Status: Offline Sonork: 1680285 Thanks Meter: 226 | https://mega.nz/#F!BUpkVKbI!UiCde4TembMpRzKQs1oT1A firmware for a45d |
The Following 3 Users Say Thank You to choksi For This Useful Post: |
05-12-2018, 08:55 | #7 (permalink) |
Member: 2555393 Status: Offline Thanks Meter: 268 | phone dead after flash .... Card found : 7A5A6AEC , v0136 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r2 Created by Infinity-Box (c) 2018 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : MRA58K Display ID : AZUMI_KIREI_A45_D_SA_V02 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-05-05 Build Time : 1499904969 Product Model : Azumi_KIREI_A45_D Product Brand : Azumi Product Name : KIREI_A45_D Product Device : KIREI_A45_D Product Board : KIREI_A45_D Product Manfct : Azumi Board Platform : mt6570 Product Info : KIREI A45 D Operation : Write Flash [ v2.00 r2 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :9 [FL] : Set : preloader_jc45btlc.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : secro.img [FL] : Set : logo.bin [FL] : Set : md1rom.img [FL] : Set : system.img [FL] : Set : userdata.img [FL] : Total size : 0x529781A8 [ 1.29 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM114) MODE : BOOTROM PORT : 114 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6570 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6570 EMI : SRC : preloader_jc45btlc.bin EMI : CNT : 0003 EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 1.00 GB ] EMI : [02] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH_MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
01-30-2019, 14:07 | #8 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | I have same exactly problem I received mine having a restart problem, I formatted and flashed it with Sp flashtools and now dead, C2M gives error DA, SP FLASHTOOLS also givibge error DA |
01-30-2019, 21:19 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | @Fragga if you receive phone for repair with strange problem best way is to read info first with CM2 and then you can post log text here before write flash. |
08-12-2019, 10:43 | #10 (permalink) |
Junior Member Join Date: Nov 2018
Member: 2878071 Status: Offline Thanks Meter: 0 | Hey kindly help me I was flashing azumi kirei a4d using SP flash too, the flashing completed and I tried to power on the phone but nothing happened, the phone is dead. I tried to repeat the flashing thinking maybe the system didn't flash okay but upon flashing I'm receiving this ERROR: STATUS_DA_HASH_MISMATCH(0XC0070004). What is needed please help! |
