03-26-2015, 12:20 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: ANDROID HEART
Member: 724704 Status: Offline Sonork: 100.1605390 Thanks Meter: 92 | request to fix Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0091 , [Hynix] H9TA4GH2GDMCPR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info MTKxCPU : MT6572 MTKxPRJ : huaqin72_we_iba_lca Saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__huaqin72_we_ib a_lca.ispff Done! Elapsed: 00:03:55 Reconnect Power/Cable! Load File Bad file detected! Load File Bad file detected! Load File Bad file detected! Load File Bad file detected! |
03-26-2015, 12:26 | #2 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
