Old 08-04-2017, 18:33   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Hurricane Freedom Dead After Flash
I got this tablet with stuck on startup. I downloaded a file and flash it with Sp Flash Tool
after complete flash now its dead. I try to connect it with pc but not luck. I connect it with normal and holding volume bottons . Then i try to connect KCOLO and KCOL1 with GND. but same . Please tell me what to do.
On board it showing MT8312CA But at info it showing MT6572.
I used this firmware to flash.
Hurrican Freedom 3g MT6572 100% (celltech-+263785525466)
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 8801034E436172642043FCCE3D60A2D3
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:15
Reconnect Power/Cable!
Flashing Log
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0xBE0B0000
EMICFG_RET_FAILED
CodeDefine : DA_DRAMC_RANK0_CALIBRATION_FAILED
Boot Error!
Operation Failed
Elapsed: 00:00:24
Old 08-04-2017, 18:41   #2 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Log Before Flashing.
Start at : [8/4/2017 / 9:47:25 AM]
Wait for phone...
Phone found! [ 544 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x88 , OEM : 0103
[eMMC] : FLASH_INF : [FORESEE] , draC
[eMMC] : FLASH_CID : 8801034E436172642043FCCE3D60A2D3
[eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E7400000
[eMMC] : FLASH_UCP : 3700 MiB [eMMC 4 GiB]
DEV RID : 0xBF15704B4FD899C25BF15D4A96D67302
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : alps
ProdName : Hurricane
ProdModel : Freedom
Device : Hurricane
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.KK1.MP7.V1.44
SECURITY :
IMEI_SW [1] : 868254022870343
IMEI_SW [2] : 868254022870350
BTMAC Addr : 54EF92FACE3C
WiFi MAC : 54EF92B477B6
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V72_1_wg_n
EXTRA :
LCD [0] : tf070mc124_dsi
LCD Res : 1024x600
TOUCH [0] : gslX688
CAM [0] : s5k4ecgx_yuv
CAM [1] : gc2035_yuv
CAM [2] : gc2155_yuv
CAM [3] : gc2145_yuv
CAM [4] : bf3920_yuv
CAM [5] : gc0328_yuv
CAM [6] : gc0308_yuv
CAM [7] : gc0329_yuv
CAM [8] : gc0311_yuv
CAM [9] : gc0312_yuv
CAM [10] : bf3a03_yuv
CAM [11] : bf3703_yuv
MODEM : elink12c_w2_hspa
LOCALE : en_US af_ZA am_ET ar_EG ar_IL bg_BG bn_IN ca_ES cs_CZ da_DK de_AT de_CH de_DE de_LI el_GR en_AU en_CA en_GB en_IE en_IN en_NZ en_SG en_ZA es_ES fa_IR fi_FI fr_BE fr_CA fr_CH fr_FR hi_IN hr_HR hu_HU in_ID it_CH it_IT iw_IL ja_JP km_KH ko_KR lt_LT lv_LV ms_MY my_MM nb_NO nl_BE nl_NL pl_PL pt_BR pt_PT rm_CH ro_RO ru_RU sk_SK sl_SI sr_RS sv_SE sw_TZ th_TH tl_PH tr_TR uk_UA ur_PK vi_VN zh_CN zh_TW zu_ZA
Done!
Elapsed: 00:00:08
Finish at : [8/4/2017 / 9:47:34 AM]
Start at : [8/4/2017 / 9:48:27 AM]
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:22
Finish at : [8/4/2017 / 9:48:50 AM]
========================= Start =========================
8/4/2017 / 11:28:36 AM
Card found : S/N : C7434459 , v0136
Scatter Load Ok , BaseBand : MT6572 , Project : nck_team , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Start at : [8/4/2017 / 11:29:48 AM]
======= Flash
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : nck_team , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : eMMC NOT supported by BootLoader!
[BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone!
Operation Failed
Elapsed: 00:00:11
Finish at : [8/4/2017 / 11:29:58 AM]
Start at : [8/4/2017 / 11:30:46 AM]
======= Flash
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
BL : Skip checking by User request!
BL : BatteryLevel : 3686 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000A00000-0x0000000000100000
Erase : 0x0000000002700000-0x00000000E4020000
Flash Pre-Erase Done, time used : 00:00:01
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : PRO_INFO
Write Error , code 0x000! Something went wrong!
Operation Failed
Elapsed: 00:00:13
Finish at : [8/4/2017 / 11:30:58 AM]
Old 08-04-2017, 22:25   #3 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 707
right here...why do you untick this button? now you cry cry cry...you killed your mobile by yourself...
the software warned your but you did not listen...try finding the right firmware for your phone AND NEXT TIME ALWYS BACKUP FIRMWARE BEFORE OPERATION
The Following User Says Thank You to nessyb For This Useful Post:
Old 08-05-2017, 20:55   #4 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Thanks for your reply Bro. How can I find a correctfirmware. I tried but nothing got. Please give me a firmware or link. Please
Old 08-06-2017, 08:43   #5 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Find correct firmware and flash phone.
Br.
Infinity Box Team.
Page generated in 0.23646 seconds with 9 queries
