12-15-2015, 18:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | [Request] Y330-u01 stuck in logo, pleas Flash dump for repair it 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 65 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Ver : MTK_AllInOne_DA_v3.3001.00.00 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040301A5901171DD [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! regards |
The Following User Says Thank You to Steve-1 For This Useful Post: |
12-15-2015, 20:19 | #2 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Quote:
The Following User Says Thank You to johnmadzeka1 For This Useful Post: |
12-16-2015, 11:22 | #6 (permalink) | |
Member: 2501288 Status: Offline Thanks Meter: 328 | Quote:
12-16-2015, 11:48 | #7 (permalink) |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Here is log and screen shot Flashing info: Code: Operation : Flash [ v1.39 ] ======= Flash Files set for flashing : [ MCU ] : 6572_Temp_dump.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Ver : MTK_AllInOne_DA_v3.3001.00.00 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040301A53F9D6111 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : Huawei ProdName : Y330-U01 ProdModel : HUAWEI Y330-U01 Device : hwY330-U01 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.37 ISPFF ID : 6572 , TARGET ID : 6572 FlashFile is differs from eMMC settings, continue by user request Flash pre-erase disabled Write Flash now ... [ MCU ] : 6572_Temp_dump.ispff Prepare SC failed :( |
12-17-2015, 18:55 | #8 (permalink) |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | What can we do problem not yet solved and still got phone in hand? |
