07-01-2008, 09:24 | #12 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | tnx for pinout' fomat ffs successfully & phone ok now but new firmware detected log here CPU: MT6225 high speed boot enabled chip: 0001C03:000E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.FD7BE778.[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_E70F29F2].rpl ==================== New firmware detected: JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: FD7BE778 identification#1 protocol ver: 04 ver. sw1: JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN ver. sw2: MAUI.07A.W07.52.MP.V2, 0DD6F018 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E40000 Detected eeprom/ffs address is non-standard: 00E40000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E40000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 001C0000 ffs chip: 00 eeprom/ffs area: 00000000:00E40000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN]_20080701-125231.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22202200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_FD7BE7 78_JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_M P_V2.BIN_E70F29F2_20080701-125324.B0X.bin Finished, time used: 161 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to alamgir80 For This Useful Post: |
I need pinout nokia 6300 rh-37 | MOURAD™ | Multi-box LITE | 7 | 10-08-2008 12:53 |
6300 rh-37 pinouts | bart simms | Infinity-Box | 3 | 09-13-2008 15:16 |
6300 rh-37 new tested pinouts | bart simms | Infinity-Box | 2 | 09-13-2008 10:51 |
do not scan pinout 6300 use pin nokia rh-37 | Tamansu | SpiderMan | 0 | 01-04-2008 05:23 |
