09-29-2017, 13:27 | #1 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Rivo A525 Fixed Dial Only not done i got phone and when dial any phone number , it says Fixed dial number only. i formatted ,phone but did not solved Problem . here is the log Operation : Reset Settings [ v1.00 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Preparing PMT Verifying PMT Erasing 1474560 bytes FileSystem format done! Done! Elapsed: 00:00:58 Reconnect Power/Cable! |
The Following User Says Thank You to khanzada606 For This Useful Post: |
09-29-2017, 13:36 | #2 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | world First Rivo a525 Read flash done Operation : Read Flash [ v1.00 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Read done, 0x00400000 |
09-29-2017, 17:10 | #3 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | there were an option in securty setting fixed dial numbers only that option were enable for disable need password after format no luck . please make possible to remove or read user code. |
09-29-2017, 19:19 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Code is default : 0000 ( or 00000 or 00000000 ) 12345 This is default user codes. If code not accepted - need check device dump Next time try to follow thread title and make another one , if have troubles with another thing/device. Also - post full logs. Not cut them. |
09-29-2017, 20:33 | #6 (permalink) | |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Quote:
i have dump of later i will upload | |
