02-16-2016, 08:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | rivo rx 80 repair imei error Operation : Read Flash [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513758534142018A79C4F142FF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 150100513758534142018A79C4F142FF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : C454D5CDAD4465744E0F47E5B60532DB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : RHYTHM ProdName : RX80 ProdModel : RHYTHM RX80 Device : RX80 AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : RIVO_RHYTHM_RX80_S010_20150507 [Read Ok] : preloader_zaw720.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / zaw720 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1806 MiB Scatter saved to : C:\Documents and Settings\SAGAR NADEEM\Desktop\MT6582__RHYTHM__RHYTHM_RX80__RX80__ 5.0__RIVO_RHYTHM_RX80_S010_20150507\ All done! Done! Elapsed: 00:07:29 Reconnect Power/Cable! Operation : Repair Security [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 150100513758534142018A79C4F142FF Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 150100513758534142018A79C4F142FF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : C454D5CDAD4465744E0F47E5B60532DB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error on Security Repair , Code : 0x1 Make sure about mobile is working and alive! Check BaseBand state also, fix if need! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! |
02-16-2016, 08:27 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Check Baseband state first, if unknown fix it first. After try to repair security with CM:Permanent mode. Br. Infinity Box Support Team. |
02-16-2016, 09:18 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | In folder : C:\Documents and Settings\SAGAR NADEEM\Desktop\MT6582__RHYTHM__RHYTHM_RX80__RX80__ 5.0__RIVO_RHYTHM_RX80_S010_20150507\ you have now MAUI DB file , like MT6582_S00_MOLY_LR9_W1444_MD_LWTG_MP_V8_P7_1_lwg_n Download and open latest MAUI Meta ( can find on needrom or etc , better v8 or v9 ) , connect phone and select that DB, which CM2 made. Repair your IMEI's. |
02-16-2016, 12:08 | #5 (permalink) | |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Quote:
pro sove thanks sir | |
