03-28-2016, 13:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2015
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | Rivo RX35 NAND MT6572 Factory File Read Done By Infinity Box Rivo RX35 NAND MT6572 Factory File Read Done By Infinity Box Code: Operation : Read Flash [ v1.44 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 9 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : EF4B65A1ED1D4F7003F80B66F22750FE INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_a7n_ax_huge_501_rivo_rx35.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT6572 / V1.1.1 / a7n_ax_huge_501_rivo_rx35 / NAND FW Size : 335 MiB Brand : RX35 ProdName : a7n_ax_huge_501_rivo_rx35 ProdModel : RX35 Device : a7n_ax_huge_501_rivo_rx35 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : a7n-ax-501-rivo-rx35-v01002 Android Info saved Scatter saved to : E:\MT6572_NAND_RX35__RX35__a7n_ax_huge_501_rivo_rx35__4.4.2__a7n-ax-501-rivo-rx35-v01002 Done! Elapsed: 00:03:06 Reconnect Power/Cable! Br Suny125 |
The Following 5 Users Say Thank You to Suny125 For This Useful Post: |
