01-01-2018, 09:07 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Rivo Sapphire S580 RDA8851x Boot File Not Found Code: Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 910E970F Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C Boot Done! Elapsed: 00:00:30 Done Reconnect Power/Cable! Code: Card found : S/N : 2DD5E586 , v0136 Chinese Miracle II [RDA module] v 1.05 Operation : Check Device / Info ======= Settings Settings : Read AllInfo is Off Settings : Full Boot disabled by default Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 910E970F Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C Boot Done! Elapsed: 00:00:30 Done Reconnect Power/Cable! Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 910E970F Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! Code: Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 910E970F Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! |
01-01-2018, 13:27 | #3 (permalink) | |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Quote: Code: Operation : Identify [ v1.02 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! inf_usb-dll:err [_usb_read_async] timeout error BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x00600000 BOOT_MODE : UNKNOWN Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! | |
