01-13-2017, 08:18 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Rivo Sapphire S580 RDA8851x read full backup successfully by CM II Rivo Sapphire S580 Read Full Backup Successfully By CM-II RDA Module Code: Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 6E076B01 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851X ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 8809 , 00400000 Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851C Target Flash : flsh_spi32m Project Name : C41_RIVO_V02_0803 Project Info : 8851C_QVGA_X915 [BIN] Saved as : C41_RIVO_V02_0803_8851C_QVGA_X915_CT8851C_flsh_spi32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C41_RIVO_V02_0803_8851C_QVGA_X915_CT8851C_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C41_RIVO_V02_0803_8851C_QVGA_X915_CT8851C_flsh_spi32m.ifc Build done Done Elapsed: 00:00:50 Reconnect Power/Cable! GSM City |
The Following 4 Users Say Thank You to Muhammadsaqib11 For This Useful Post: |
07-08-2017, 08:45 | #2 (permalink) |
Freak Poster Join Date: May 2012 Location: Pakistan Panjab, Sahiwal
Member: 1758871 Status: Offline Sonork: Zaka Ullah Bhatti Thanks Meter: 144 | Rivo Mobile Sapphire S650 Flash CM2 Read Done Rivo Mobile Sapphire S650 Flash Read Done Operation : Read FullFlash ======= Settings Settings : SafeMode is Off [Fast] Settings : Make IFF (MCU) file Settings : Make Calibration file Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 6E076B01 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851X ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 8809 , 00400000 Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! Read Flash now ... Read Ok, 4194304 bytes read Verify file... Target BbCpu : CT8851C Target Flash : flsh_spi32m Project Name : C41_RIVO_V02_0803 Project Info : 8851C_QVGA_X915 [BIN] Saved as : C41_RIVO_V02_0803_8851C_QVGA_X915_CT8851C_flsh_spi 32m.bin Make FlashFiles FATNV Check passed FSCSC Check passed CALIB Check passed [IFF] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C41_RIVO_V02_0803_ 8851C_QVGA_X915_CT8851C_flsh_spi32m.iff [CAL] File saved to : C:\InfinityBox\CM2RDA\Flash\IFF\C41_RIVO_V02_0803_ 8851C_QVGA_X915_CT8851C_flsh_spi32m.ifc Build done Done Elapsed: 00:00:49 Reconnect Power/Cable! By Zaka Ullah Bhatti -------------------------------------------------------- https://drive.google.com/file/d/0B1k...RpWnkzUUk/view |
The Following 2 Users Say Thank You to bhatti123 For This Useful Post: |
10-27-2017, 09:39 | #3 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: In your heart.
Member: 1973579 Status: Offline Thanks Meter: 30 | Quote:
Kindly guide me how to connect this phone? Thanks anticipation! | |
11-05-2017, 12:50 | #5 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 34
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | Rivo Sapphire S530 Slow response & user code problem solved via format Code: Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 6E076B01 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851X ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 8809 , 00400000 Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05954 , 81C05968 CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:00:29 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to EjazATF For This Useful Post: |
