03-13-2011, 16:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: india Age: 39
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | rocker diamond blink & ded infinity team COM19 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8B00:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 11 sec Remove/Install battery now ! aafatr in use-->> outodetect bend rate & formet ffs complete log COM19 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8B00:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 19 sec Remove/Install battery now ! pls help me |
03-13-2011, 16:50 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Press power button for more longer time and see result. If it didn't works out then make full flash backup and try with complete mode format. Wr. |
03-13-2011, 16:59 | #3 (permalink) |
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | tray this full flach same prob COM19 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8B00:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 13 sec Remove/Install battery now ! |
03-13-2011, 17:21 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | -Open Chinese Miracle-3.27 (use latest for best result) -On "Settings" page you will see first option tab "Model" with option "Autodetect 6205-6239 NOR" -Click on "Model" tab and select last option "Autodetect 6253 NOR". Wr. |
03-14-2011, 07:34 | #7 (permalink) |
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | v.3.27 & autodidact 6253 nor siclect pls help me COM3 [VCP1] selected module v3.27 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6235:8B00:8A00 status: 00 bbchip bl ver: 00 NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: 00 error: can not boot device: 07E9:S_BROM_LOCK_POWERKEY_FAIL error: last error: 07E9:S_BROM_LOCK_POWERKEY_FAIL Disconnect... done Finished, time used: 6 sec Remove/Install battery now ! |
03-14-2011, 08:45 | #8 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Try to make full flash back up and format in COMPLETE mode with "Autodetect 6209-6239 Nor" option, since now you have installed latest CM. Let's see the result now. | |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
winlock & counter | Knight | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-03-1999 20:49 |
About 5110 & Winlock | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-08-1999 03:54 |
Nokia 5110 & 6110 Schemics | MyKy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-06-1999 08:36 |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
