01-27-2011, 16:07 | #1 (permalink) |
Registered User Join Date: Oct 2005
Member: 189506 Status: Offline Sonork: 100.1576871 Thanks Meter: 126 | Rocker f16 mt6253n failed to format i try to formating rocker E16 ,but it failed to formating.. also unable to read the firmware Here is the Log:- COM14 [VCP0] selected module v3.26 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND warning: can not format: HW_STORAGE_NAND is not present Format... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND error: last error: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND Disconnect... done Finished, time used: 1 min 10 sec Remove/Install battery now ! need help |
01-29-2011, 10:04 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Hello here is also same error with HTTEL K3 problem dead COM3 [VCP0] selected module v3.26 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_LOCKED/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND warning: can not format: HW_STORAGE_NAND is not present Format... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND error: last error: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND Disconnect... done Finished, time used: 1 min 24 sec Remove/Install battery now ! |
02-01-2011, 09:57 | #6 (permalink) | |
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Quote:
Hello read from same ok phone flash file & write to your foulty phone....... | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
