rome zte g-231 unlocking error please help OM7 selected module v2.86 Action: read codes unlock method: read codes Model: Aiko-17G Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 72 byte(s) read imei: D445B413000000 connection Ok 77 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 32 byte(s) read error: source data size is less than expected error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! |
Please, select correct model and try to unlock phone again. |
COM10 [VCP2] selected module v2.86 Action: unlock unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35424903018253 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 31 sec Remove/Install battery now ! |
COM7 [VCP2] selected module v2.90 Action: unlock unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35547302600000 connection Ok 186 byte(s) read reading data... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 18 sec Remove/Install battery now ! |
COM4 [VCP0] selected module v2.91 Action: unlock unlock method: smart fast Model: ZTE-231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 44 byte(s) read connection Ok 157 byte(s) read reading data... reading data #2... reading data #3... reading data #4... reading data #5... WARNING ! Unknown lock structure ! Read flash and send to support: [email protected] error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! |
ZTE-R231 and ZTE-231 is a different models ! You must select correct model. |
This is log please follow COM14 [VCP1] selected module v2.93 Action: unlock unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 9600 autodetect error: boot phase #2/1 failed Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 3 sec Remove/Install battery now ! |
It's a cable problem for sure. Please, double check your cable. |
two cable change already. i used just tx rx.please advice |
Hello, 3 wires should be used: Rx/Tx/Gnd If you still have a problems with initial connection, please, double check your cable. Probably you need to swap rx <-> tx wires |
where connection to gnd |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: http://www.infinity-box.com/download...shell_v126.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
COM4 [VCP0] selected module v2.94 Action: unlock unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35424903003311 connection Ok 186 byte(s) read reading data... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 100 sec Remove/Install battery now ! thanx infinity team |
what cable are u using |
