Old 09-28-2009, 11:15   #1 (permalink)
Member: 309581
Thanks Meter: 16
rome zte g-231 unlocking error please help
OM7 selected
module v2.86
Action: read codes
unlock method: read codes
Model: Aiko-17G
Checking data, wait...
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: ORANGE_ENG_EN_P107A1V1.0.4B02
Version: 08BZTENJ35_OG_08B
72 byte(s) read
imei: D445B413000000
connection Ok
77 byte(s) read
reading data #2...
reading data #3...
reading data #4...
reading data #5...
32 byte(s) read
error: source data size is less than expected
error: operation failed !
Finished, time used: 14 sec
Remove/Install battery now !
Old 09-29-2009, 09:58   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
Originally Posted by aliajk View Post
OM7 selected
module v2.86
Action: read codes
Model: Aiko-17G
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
72 byte(s) read
connection Ok
77 byte(s) read
reading data #2...
reading data #3...
reading data #4...
reading data #5...
32 byte(s) read
Hello,
Please, select correct model and try to unlock phone again.
Old 10-02-2009, 17:08   #3 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 100.1577836
Thanks Meter: 1,590
COM10 [VCP2] selected
module v2.86
Action: unlock
unlock method: smart fast
Model: ZTE-R231
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
80 byte(s) read
imei: 35424903018253
connection Ok
186 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 31 sec
The Following User Says Thank You to Y2ksalman For This Useful Post:
Old 10-06-2009, 09:25   #4 (permalink)
musmanm's Avatar
Member: 437422
Thanks Meter: 37
COM7 [VCP2] selected
module v2.90
Action: unlock
Model: ZTE-R231
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
80 byte(s) read
imei: 35547302600000
connection Ok
186 byte(s) read
reading data...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 18 sec
The Following User Says Thank You to musmanm For This Useful Post:
Old 10-24-2009, 11:50   #5 (permalink)
abdulwajid147's Avatar
Member: 213172
Sonork: 1582799
Thanks Meter: 265
COM4 [VCP0] selected
module v2.91
Action: unlock
Model: ZTE-231
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
44 byte(s) read
connection Ok
157 byte(s) read
reading data...
reading data #2...
reading data #3...
reading data #4...
reading data #5...
WARNING ! Unknown lock structure !
Read flash and send to support: [email protected]
Finished, time used: 15 sec
Old 10-24-2009, 19:54   #6 (permalink)
Member: 130995
module v2.91
Action: unlock
Model: ZTE-231
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
44 byte(s) read
connection Ok
157 byte(s) read
reading data...
reading data #2...
reading data #3...
reading data #4...
reading data #5...
Hello,
ZTE-R231 and ZTE-231 is a different models !
You must select correct model.
Old 11-18-2009, 05:41   #7 (permalink)
Member: 255638
Thanks Meter: 10
This is log please follow
COM14 [VCP1] selected
module v2.93
Action: unlock
Model: ZTE-R231
9600 autodetect
error: boot phase #2/1 failed
Can not initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method
Finished, time used: 3 sec
Old 11-18-2009, 10:30   #8 (permalink)
Member: 130995
module v2.93
Action: unlock
Model: ZTE-R231
9600 autodetect
Possible reasons:
Hello,
It's a cable problem for sure.
Please, double check your cable.
Old 11-22-2009, 06:49   #9 (permalink)
Member: 255638
Thanks Meter: 10
two cable change already. i used just tx rx.please advice
Old 11-22-2009, 10:37   #10 (permalink)
Member: 130995
Hello,
3 wires should be used: Rx/Tx/Gnd
If you still have a problems with initial connection, please, double check your cable.
Probably you need to swap rx <-> tx wires
Old 11-22-2009, 12:00   #11 (permalink)
Member: 255638
Thanks Meter: 10
where connection to gnd
Old 11-22-2009, 13:29   #12 (permalink)
Member: 130995
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 12-01-2009, 09:22   #13 (permalink)
Member: 232607
Sonork: 100.1585040
Thanks Meter: 260
module v2.94
Action: unlock
Model: ZTE-R231
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
80 byte(s) read
imei: 35424903003311
connection Ok
186 byte(s) read
reading data...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 100 sec
thanx infinity team
The Following User Says Thank You to zahid_gsm For This Useful Post:
Old 12-01-2009, 10:41   #14 (permalink)
coolmax's Avatar
Member: 157118
Thanks Meter: 156
what cable are u using
Old 12-01-2009, 15:45   #15 (permalink)
Member: 130995
Hello,
The Following User Says Thank You to InfinitySupport For This Useful Post:
M702iG unlocking error please help..... carlluvjo Smart-Clip 1 03-25-2008 10:38
Nokia 6125 Unlock Error... Please Help... kitcat J.A.F. V-SPEC 1 02-05-2008 16:44
E65 unlock error!!! please help... wildtiger J.A.F. V-SPEC 3 12-09-2007 15:53
Ku790 Unlock Error Please Help feritk ULT PRO 11 09-18-2007 10:33
7290 unlock error.please help GOODNESS FuriousGold 1 09-06-2007 16:40
Page generated in 0.46171 seconds with 8 queries
