09-12-2018, 02:17 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | RTC/PowerLatch Settings Failed #1 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 17 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6276 BB_CPU_HW : CB00 BB_CPU_SW : 0101 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6276_S0000 BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! how to read full firmware fromthis fone??? |
09-12-2018, 14:16 | #3 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | when y press * its is connected as mtk and infinity give me this: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 17 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6276 BB_CPU_HW : CB00 BB_CPU_SW : 0101 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6276_S0000 BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! |
09-13-2018, 23:42 | #4 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | UNSUPPORTED DEVICE??? Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM17) MODE : BOOTROM PORT : 17 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT0000 , SBID : 0x0000 , HWVR : 0x0000 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! |
09-14-2018, 14:37 | #5 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
What is phone model? Legacy phones are supported by CM or CM2MTK. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
09-14-2018, 22:37 | #6 (permalink) | |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Quote:
Name is crosscall shark v3 link https://crosscall.com/en/shark-x3/ y try wed cm2mtk and give that error above.. | |
09-14-2018, 22:41 | #7 (permalink) | |
On InfinityBox CM2MT2 give this: UNSUPPORTED DEVICE??? Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM17) MODE : BOOTROM PORT : 17 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT0000 , SBID : 0x0000 , HWVR : 0x0000 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! and wed cm2mtk give this: when y press * its is connected as mtk and infinity give me this: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 17 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6276 BB_CPU_HW : CB00 BB_CPU_SW : 0101 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6276_S0000 BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! y dont now what y am doing rong???? | |
07-28-2019, 08:52 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I'm looking for more samples nowdays, have just ONE MT6276 sample here and can't by this one add others. |
