Old 05-22-2009, 15:26   #1 (permalink)
Member: 358277
Thanks Meter: 476
s-90 flash write error
here r logs COM6 [VCP0] selected
module v2.81
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:F503:0000
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
New firmware detected (v.2.81, database date: 01.05.2009):
A200_PCB01_GPRS_MT6225_S00.V06_ENFRARRUSPPTPEVITR_ AL.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: A200_PCB01_GPRS_MT6225_S00.V06_ENFRARRUSPPTPEVITR_ AL.BIN
ver. sw 2: A200.V06.EnFrArRuSpPtPeViTr.AL, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
error: no any expected answer
error: flash write error: 00F00000:00002000
error: unexpected termination/freez: 00000000
Write Fail
Finished, time used: 145 sec
Remove/Install battery now ! set was dead by mistake set removed during formating. after too much search i found a set with same flash file i read both eeprom & firmware then i write this file in it but at 93% it is giving error .i have clean board reheat flash chip. error is same plz give me solution i m too much confused for this.
Old 05-24-2009, 11:08   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
If flash can not be written it may be that flash chip is damaged or bad soldered.
Try to reball flash chip or at least Heat it.
Old 01-13-2010, 10:08   #3 (permalink)
muhammad khalid's Avatar
Member: 313337
Sonork: 100.1582697
Thanks Meter: 106
when you write new flash files on infinity box.these things are to keep in mind.
1. when you flash new firmware, ffs is disturbed.then you format that on standard address.after flash complte when you will format the address will be selted and format will go on.
2. during flash or format some mobile required to press power button till at the end of completion.when you leave the power buttton flashing or format stopped with different errors depend upon the process running.
3. during format or flash when ever you cable is discocected or power is disturbed, infifity process show the wanings with errors and retry for some time , if you press and keep the power ON buttong, it will recover the error during the process and continue further at right direction.
judge your self, which point guide you
All above procedures are my own experience. So use with your risk
Old 02-13-2010, 10:03   #4 (permalink)
Member: 159105
Thanks Meter: 60
sam probeme
i have sam problem with many phone
search sec info#1 finished
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
flash: 98006F00000004:18E59F00000000
Write: Firmware
error: error# 000000FF
error: flash write error: 00000000:00002000
2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BF42E3B3B3BFC2E3B3B3BEC 2E3B3B3BF62E3B3B3BBA1A2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3B
error: write operation failed
Write Fail
Finished, time used: 4 min 32 sec
Old 02-14-2010, 09:20   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
Area: Firmware
Write: Firmware
Write Fail
hello!
you must be using Spiderman is interface?
6230i cant flash after mcu flash Write Error ?? AnToS Twisterflasher 16 07-13-2005 20:22
6610 flash write error baraka42 Twisterflasher 4 04-12-2005 12:44
Maxon 7922 Flash Write Error at 101000 ??? While Flashing UNLOCKED Flash File Aamir_Zia Redbox 8 12-09-2004 19:11
3310 flash writing error Moosani Nokia Hardware & Hardware Repair 0 09-02-2003 10:55
Page generated in 0.18062 seconds with 9 queries
