09-29-2008, 16:18 | #1 (permalink) |
Insane Poster Join Date: Jun 2008 Location: Argentina
Member: 800178 Status: Offline Thanks Meter: 1 | Itīs UTSTARCOMM778 supported? Also, i have not the cable. or one of itīs replacements. Can you share to me "how to" make it? Looks like Pantech connector pins... and i must now this to make the cable: ( no tester ) If says -just exemple ) pin 12 RX --------> pin 3 rj45 simply solde a cable to that pin and connect it to that rj45 pin and MUST work??? if allready exist a cable on the pin 12 of the plug, can i use it and would work? Thanks in advance! |
09-29-2008, 16:25 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, This phone is supported. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
09-29-2008, 21:21 | #3 (permalink) |
Member: 800178 Status: Offline Thanks Meter: 1 | 42 can be alittle more specific? need to do im** repair to this phone. can i make it? only see in service **** the unlock command. There is a hide possibility? ty again. |
09-29-2008, 21:46 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Currently im** function is not supported for this model (you can check it by yourself, just run software, select required model and you will see what buttons exist in software "Service" page) but we will try to upload some files in support area today, so you will be able to try to make cloned im** (try to write repair eeprom files). Don't forget to read flash from your phone before any operation and it will be good if you will send full flash backup to [email protected] |
can it be added support for siemens and sagem phones on furious dongle? | bashtanii | FuriouS II | 0 | 02-12-2006 00:03 |
It is oficial support site or not? | rambo amadeus | VygisToolbox | 12 | 09-04-2005 07:13 |
GD87/GD88 will it ever be supported? | cracker_jack | Infinity-Box | 1 | 09-01-2005 07:43 |
New C975 Boot Loader 0.6.3.1 When it Will be Supported .. | Aamir_Zia | Smart-Clip | 5 | 06-10-2005 07:03 |
V890 New Model :( When it Will be Supported by Smart-Clip ??? | Aamir_Zia | Smart-Clip | 6 | 01-05-2005 22:25 |
