Old 09-28-2016, 13:58   #1 (permalink)
Member: 2413485
Thanks Meter: 11
s1la40 [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Operation : Format FileSystem [ v1.56 ]
Wait for phone...
Phone found! [ 166 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Boot Error!
Operation Failed
Elapsed: 00:00:19
Reconnect Power/Cable!
Operation : FastBoot : Unlock BootLoader [ v1.56 ]
Power Off Phone , re-connect battery , Insert USB cable!
Wait for phone...
Sync...
Protocol : 0.5
Device : AL817ROW
Storage : eMMC
BootLoader : Locked
Warranty : Not tampered ( Under Warranty )
Secure : Enabled
ExtraStat : FB Load Supported!
Boot Lock/Unlock Failed
How reser frp?
Old 09-28-2016, 15:33   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,013
Hello,
Try to connect holding both volume keys, result?
Br.
Infinity Box Support Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 09-30-2016, 09:44   #3 (permalink)
Member: 87188
Thanks Meter: 202
Operation : SP Unlock [ v1.56 ]
Mode : Direct Unlock
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 510001154D3331335E2C0642159658FE
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x80000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM313
[eMMC] : FLASH_CID : 150100513331334D42062C5EFE58B215
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x2629251B3525378F2B49470DD39EE849
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
USBDL : Init HSUSB Ok
SIM Lock Status : Locked!
Unlocking now ...
Error while unlocking, somethig went wrong!
Operation Failed
Elapsed: 00:00:33
Old 09-30-2016, 11:37   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,929
Make sure you had installed USB drivers for preloader port and device have enough charged battery.
Use good short USB cable.
Repeat operation.
Old 09-30-2016, 14:29   #5 (permalink)
Member: 87188
Thanks Meter: 202
Driver or battery problem can not be.
I was reading the full flash.
If you are needed for the solution.
Operation : Read Flash [ v1.56 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
USBDL : Init HSUSB Ok!
xGPT : Normalize settings Ok!
Brand : Lenovo
ProdName : S1La40
ProdModel : Lenovo S1La40
Device : S1La40
AndroidVer: 5.1
MTKxCPU : MT6753
MTKxPRJ : S1La40_S_USR_S400_1605102045_MP3V2_16G_TELENOR_HU
[Read Ok] : preloader_al817row.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6753 / V1.1.2 / al817row / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 3743 MiB
Scatter saved to : D:\telefon\PDA-MDA\MTK_Android\Lenovo\Vibe_S1_Lite\MT6753__Lenovo __Lenovo_S1La40__S1La40__5.1__S1La40_S_USR_S400_16 05102045_MP3V2_16G_TELENOR_HU\
All done!
Done!
Elapsed: 00:17:56
Old 09-30-2016, 18:12   #6 (permalink)
JayDi's Avatar
Member: 462970
@Pufi164, hold phone for the next update. ETA - tomorrow.
The Following User Says Thank You to JayDi For This Useful Post:
Old 10-03-2016, 11:04   #7 (permalink)
Member: 87188
Thanks Meter: 202
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Unlocking now ...
Operation Failed
Elapsed: 00:00:30
Operation : SP Unlock [ v1.57 ]
Mode : Read Codes
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Slot[1] SIMLock Info :
[1] Level , [Locked] : True , [Count] : 7 , [Spc] : 256 , [UnlockCode] : 20641145
[2] Level , [Locked] : False
[3] Level , [Locked] : False
[4] Level , [Locked] : False
[5] Level , [Locked] : False
[6] Level , [Locked] : False
[7] Level , [Locked] : False
Slot[2] SIMLock Info :
[1] Level , [Locked] : False
Done!
Elapsed: 00:00:30
Code must be 16 digits:-(
The Following User Says Thank You to Pufi164 For This Useful Post:
Old 03-10-2018, 10:28   #8 (permalink)
gsmcrazy1's Avatar
Member: 897524
Sonork: 100,1609543
Thanks Meter: 163
Holding both volume keys working for me
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
eMMC Flash : 510001154D3331331726064277B0C2FE
[eMMC] : FLASH_CID : 150100513331334D42062617FEC2B277
DEV RID : 0xB582A661DCCB7A02916EAF366BED24B6
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:17
Best Regards
Page generated in 0.27154 seconds with 7 queries
