Old 01-12-2009, 08:12   #1 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
s211 alcatel unlock done
COM5 [VCP0] selected
module v1.30
Device: Alcatel-S211
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 012A7E2A242A00:54000000000000
flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
reading Alcatel-S211_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20090111-235936.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 78 sec
The Following User Says Thank You to nadirghazi For This Useful Post:
Old 01-13-2009, 12:21   #2 (permalink)
Member: 547967
Thanks Meter: 653
==== log opened: [1/12/2009 10:41:03 PM] ====
Application: C:\Program Files\InfinityBox\HModule\HModule.exe
Loading data, wait...
[Infinity Box] v1.23
S/N:
Wait...
Current model: Alcatel-S211
Done
COM4 [VCP1] selected
Action: unlock
Boot...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection...
Set baud...
203125
Set baud done
Check hardware...
Check hardware done
Read data...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20090112-224225.80E.bin
Read data done
Check data...
Check data done
Writing...
Write: simlock
Writing done
Finished, time used: 79 sec
Remove/Install battery now
The Following User Says Thank You to mujahid_ali For This Useful Post:
Old 01-13-2009, 19:01   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Old 07-11-2009, 19:59   #4 (permalink)
mk_17's Avatar
Member: 326512
Thanks Meter: 27
can u tell us which way used cable or ... rx tx
Old 07-12-2009, 08:36   #5 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
use 7310 zte cable..
pinfiner or spider man
Old 07-15-2009, 20:06   #6 (permalink)
Member: 130995
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
alcatel s211 sucessfull unlock bittubansal Infinity-Box 5 06-29-2009 14:05
Alcatel s211 unlock done yasermalik Infinity-Box 5 03-09-2009 07:26
Alcatel-s211 unlock done saqibmalik Infinity-Box 6 02-07-2009 16:03
alcatel ot-s211 orange unlock nightmit Infinity-Box 1 01-16-2009 20:35
Alcatel OT-S211 successfully unlocked with micro-box UnlockingLab Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 01-04-2009 22:29
Page generated in 0.16656 seconds with 9 queries
