07-22-2005, 19:32 | #1 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 56387 Status: Offline Thanks Meter: 10 | Imei Change A100 i have a Panasonic A100, flashed with the last version phone power on fine, imei ok, but barred, when i change i get this log: COM8 selected Device: A10x Checking data, wait... Boot... Press Power button now ! Connecting, wait... Boot Done Parameters... Parameters Done Check Boot block... Check Boot block Done Check space... Check space Done Check Flash-1... FLASH[320502]: 04:2250 Check Flash-1 Done Check Flash-2... Check Flash-2 Done Check Flash-3... Err: Imei not found or damaged Check Flash-3 Fail Finished Remove/Install battery now ! Time used: 45 sec What can i do?? i send a mail too, thanks so much |
07-22-2005, 22:06 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, What is real IMEI in your phone now (*#06#) ? (If you don't want to post it here, send it to me by PM). Also, compare, pls, real IMEI with IMEI on phone label. Is it the same value or not ? Quote:
Panasonic A100 IMEI Change..? | LoveLess | Infinity-Box | 1 | 06-24-2008 18:59 |
how to change with 2 sim two imei change? | senkron24 | SpiderMan | 9 | 01-23-2008 00:44 |
IMEI Change on E800 - Do i also need to change the Bluetooth ID? | gaz_0001 | SYSOL Platform | 3 | 05-11-2005 23:44 |
about A100 imei change with china box NET2000 | -=ELF=- | VLSI, Conexant, Skyworks and Old Models | 1 | 05-14-2003 17:41 |
