Old 02-03-2007, 17:15   #1 (permalink)
Member: 252201
Thanks Meter: 148
S288+ Unlocking Error: Boot Failed
I tried to unlock by flash with s288+ but this the log errors of the infinity.
COM5 selected
Checking data, wait...
Connect...
Press Power button now !
Connect Ok
Boot...
Boot fail
Finished
Remove/Install battery now !
Time used: 4 sec
PLs. help Infinity Team. The phone is dead now.
Old 02-03-2007, 17:19   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,397
@cetech
please, no need to say things like "phone dead now" because it's not true !
Infinity-Box can't kill your phone for sure so please, next time describe ituation and problem honestly, no need to say wrong things !
you must check phone battery
you must check cable (see support area)
you must check phone hardware
Old 02-03-2007, 18:57   #3 (permalink)
Member: 252201
Thanks Meter: 148
Sir this is really true.
Battery full charge, cable ok tested brand new and box ok.
Actually before it can't connect i open the phone, i see the connection of the cable terminal phone side was open. i make jumpers as shown in the pin outs.
onnector: 18-pin
KEYBOARD TOP
1.........18
15: Rx (connect to pin-3 via 10k resistor)
16: Tx (connect to pin-3 via 10k resistor)
17: Gnd
When i try to unlock by flash. That logs posted below was the error.
I know infinity is good but this is my first time to unlock s288+. My first time experience also that the phone wont turn on with infinity.
This is not to offend the infinity team but to show the real and Im deserving for support because i have an original infinity box(red).
So please Infinity TEam.
Old 02-03-2007, 19:04   #4 (permalink)
Member: 130995
As you can see in your log: phone was not flashed, no any operations was made with phone so phone can't be damaged.
If phone was dead before: try to flash it with different flash files.
If no connection: try to change rx <-> tx wires
Old 02-03-2007, 19:14   #5 (permalink)
Member: 252201
Thanks Meter: 148
Sir the phone before is ok. All i need is only to unlock it. Try your suggestions. Thanks.
Old 02-04-2007, 07:06   #6 (permalink)
Member: 252201
Thanks Meter: 148
The phone is now revived but boot failed and still smartlocked.
Old 02-04-2007, 10:38   #7 (permalink)
Member: 130995
How it was happend that phone revived ?
My advice: check cable, check phone hardware carefully.
6300 china error: boot phase#1 failed ufsx002 Infinity-Box 1 01-20-2010 18:05
T303 unlocking show Boot fail aukonline Infinity-Box 1 11-18-2009 16:51
error: boot phase#1 failed aikonmani Infinity-Box 2 03-24-2009 12:11
v3x unlocking always boot fail mccm Smart-Clip 10 05-21-2006 10:20
Page generated in 0.27899 seconds with 8 queries
