10-13-2008, 07:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: INDIA-uttranchal-rishikesh Age: 47
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | s3 it problem is calibrate tough screen ??? Code: Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:D283:D375 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: G508.B_ZYZX_E_V1.2.2.E.E Version: G508_HW detecting structure #2... done 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 160 86 of 160 items cleared 0 items remains Finished, time used: 369 sec Remove/Install battery now ! ==== log opened: [10/12/2008 11:28:39 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] v2.61 S/N: 12F4:0111 Wait... Device: Autodetect 6205-6227 NOR Done error: can't open COM5 WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [10/12/2008 11:30:22 PM] ==== COM5 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:F803:000B Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605 Version: GINWAVE25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 130 130 of 130 items cleared building list... done 0 items remains Finished, time used: 21 sec Remove/Install battery now ! ==== log: [10/12/2008 11:30:55 PM] ==== COM5 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:F803:000B Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605 Version: GINWAVE25_06B_HW detecting structure #2... 0 done 44 byte(s) read warning: wrong packet cs imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 0 1 2 done 163 byte(s) read writing data... verification... verification Ok Finished, time used: 17 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [10/12/2008 11:34:06 PM] ==== COM5 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide error: operation failed ! Finished, time used: 7 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [10/12/2008 11:34:31 PM] ==== COM5 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:F803:000B Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605 Version: GINWAVE25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 130 130 of 130 items cleared building list... done 0 items remains Finished, time used: 24 sec Remove/Install battery now ! ==== log: [10/12/2008 11:38:41 PM] ==== COM5 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:F803:000B Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605 Version: GINWAVE25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... 1 2 3 4 done 163 byte(s) read writing data... verification... verification Ok Finished, time used: 11 sec Remove/Install battery now ! ==== log: [10/12/2008 11:43:54 PM] ==== COM5 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:F803:000B Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605 Version: GINWAVE25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... 1 2 3 5 6 7 8 9 10 11 12 13 14 15 16 17 18 done 163 byte(s) read writing data... verification... verification Ok Finished, time used: 50 sec Remove/Install battery now ! Last edited by SAN INFOTECH; 10-13-2008 at 08:00. |
i have a problem with calibration in sigmatel s3 | krunal1987 | Infinity-Box | 0 | 07-17-2009 15:20 |
i have A PROBLEM FOR N73 his screen is white i try 2 way bat it is not ok | abousalma007 | Nokia Hardware & Hardware Repair | 1 | 06-30-2009 20:49 |
N82 CRAZY problem in calibration touch screen | MDK23 | Infinity-Box | 3 | 01-08-2009 02:43 |
N82 problem in calibration touch screen | MDK23 | Infinity-Box | 1 | 01-07-2009 21:43 |
T68i no screen illumination and problem is not from screen | Burnt Cobba | Sony Ericsson Hardware Repair | 8 | 08-28-2003 13:57 |
