07-16-2009, 19:23 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | s3 touchscreen calibration failed... some says successful but when i switch on the set it again asks for calibration .. please help infinity team .. thanks... |
07-17-2009, 22:46 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if all calibration methods do not work- you must send us this firmware [email protected] write in subject "touchscreen calibration failed" |
07-29-2009, 22:41 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to calibrate touchscreen (if touchscreen panel is damaged): 1. connect cable from box to phone 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model 6. go to software "Settings" page and select COM port 7. make full flash backup for emergency case 8. go to software "Service" page 9. select calibration "mode-1" 10. make "Reverse calibration order" un-checked 11. press "Calibrate touchscrren" button and follow instruction given by software 12. if software can not make calibration with "detection failed" error: - select other calibration mode (f.e. "mode-2", "mode-3" etc. one by one) - repeat calibration process - test phone after each "mode" try 13. if calibration process finished without errors but touchscreen can not work well: - DO NOT change calibration "mode" ! - make "Reverse calibration order" option checked - repeat calibration process again - test phone 14. if still no luck with calibration after all tries: - make full flash backup for emergency case - make "format ffs" - Power-On phone - Power-Off phone by "Power" button (do NOT remove battery) - Repeat "Calibration" operation again - if still no luck read full flash and send to support with subject: touchscreen calibration failed |
08-06-2009, 23:25 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Touchscreen calibration procedure changed, ChineseMiracle v2.88 released: http://forum.gsmhosting.com/vbb/showthread.php?t=801258 Please, try to calibrate phone with new software, waiting for your results. |
Touchscreen calibration failed | IkaMazini | Infinity-Box | 8 | 08-06-2009 23:24 |
Ztc N328 touchscreen calibration failed | KK Mobile | Infinity-Box | 1 | 05-06-2009 20:20 |
<<< China A666 Touchscreen Calibration Failed >>> | khadim100 | Infinity-Box | 2 | 04-05-2009 11:36 |
Touchscreen calibration failed in N99i | lie_james | Infinity-Box | 1 | 01-23-2009 19:40 |
subject: touchscreen calibration failed : New firmware detected (2.70) | Faisal_Computer | Infinity-Box | 1 | 12-06-2008 13:57 |
