03-05-2009, 16:40 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: IN YOUR HEART
Member: 109163 Status: Offline Thanks Meter: 75 | S320 not powering after try unlock COM16 [VCP1] selected module v2.66 Device: Alcatel-S320X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:3189:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090305-151528.B0X.bin Area: Firmware flash: 98004900000002:2AEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16AB12 done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090305-152440.B0X.bin Finished, time used: 579 sec Remove/Install battery now ! now phone only start up log then going to power off. I also try repair security area problem not solved. for flashing no have same version file in support area i have readed file any idea? |
03-05-2009, 17:30 | #3 (permalink) |
Member: 109163 Status: Offline Thanks Meter: 75 | Done by complete FORMAT. COM16 [VCP1] selected module v2.66 Device: Alcatel-S320X Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:3189:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og__JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_3 6_SP1_V20.BIN_FFFFFFFF_20090305-162613.B0X.bin Finished, time used: 42 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
03-05-2009, 18:24 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can make "format ffs" box checked during flash process to avoid this kind of problems in future, so software make "format ffs" during flash process. |
s320 not power up | abu3131 | Easy-Unlocker | 1 | 02-03-2009 17:07 |
v3 not power after unlock | yuval44 | Motorola P2k | 1 | 09-07-2006 15:24 |
Philips FIsio 120.....after try unlock want pck code :( | Nestor7 | Philips | 0 | 03-26-2004 17:39 |
