06-30-2009, 10:28 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: türkiye Age: 59
Member: 7114 Status: Offline Thanks Meter: 51 | s320 x patch 2.79 not work correctly module v2.79 Device: Alcatel-S320X Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 353618008808901 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:0E3E:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... ................................................ ................................................ ................................................ ......................... original data found, method-B Patch required data Done Special operation ... Special operation Done Write ... flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: imei detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CH16BM13 done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S320X_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07 _36_SP1_V20__system_log__FFFFFFFF_20090630-122413.B0X.bin Finished, time used: 363 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! phone with restart after flash alcatel logo always; pls check this I am ready to work on it. Last edited by ardagul; 06-30-2009 at 10:34. |
06-30-2009, 10:32 | #2 (permalink) |
Member: 7114 Status: Offline Thanks Meter: 51 | I try to reset setting and imei seen mistakes heres the log: COM4 [VCP0] selected module v2.79 Action: reset settings Model: Alcatel-S320X Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:0E3E:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: MAUI.07A.W07.36.SP1.V20 Version: JRD23_07A_HW 44 byte(s) read imei: FF4E4B462391A0 connection Ok building list... done items to clear: 148 warning: wrong packet cs items cleared: 148 of 148 building list... done items remains: 0 Finished, time used: 23 sec Remove/Install battery now ! |
flashing cnt file 3100 not working correct | tanja1 | Twisterflasher | 5 | 11-02-2006 07:55 |
cruiser 4.79 not work, request update ! | artgsm1 | Cruiser Suite | 2 | 08-07-2006 16:18 |
Henrich Donle Problem - Dongle not work correct | menka | BF, BG, TH, BHx Series | 0 | 11-20-2004 02:39 |
T28 World not working correctly | Tin | Old Ericsson Phones & Sony Phones | 2 | 06-17-2002 15:13 |
