Old 09-25-2009, 21:36   #1 (permalink)
Member: 753891
s321 no imei change
the phone does not change the imei stays the same after the process
Old 09-26-2009, 01:41   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Could you, please, post here operation log so we will be able to check what is wrong.
Old 09-26-2009, 06:28   #3 (permalink)
Saulcell's Avatar
Member: 278939
Sonork: 100.1593095
Thanks Meter: 382
my friend with infinity box 1000000000000000% test full
luky
Old 10-09-2009, 23:53   #4 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 243
Im tried but imei not change whit flash sim free.
S321A-2ACECO1-16T_XH16YH31_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_ 07A_W07_36_SP1_V20_2009-02-04_En_Fr_Es_It_Pt_simfree.B0M.bin
But whit locked firmware imei change works.
S321A-2ACECO1-16Q_XH16NC32_JRD23_07A_PCB01_GPRS_MT6223_S00[1].MAUI_07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_Pt-BR_It.B0M.bin
The process its flash locked firmware whitout format then do imei change.
How can change imei whit full unlock??
COM6 [VCP0] selected
module  v2.90
Device: Alcatel-S321A, S321X
Checking data, wait...
Action: "repair imei"
new imei:  xxxxxxxx5503565
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:0814:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [standard] generation
rom info detection finished
rom info protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
ffs offset/size: 00C00000/00400000
ffs address assigned: 00C00000
TCL identification...
version: 16T
provider: S321A-2ACECO1
customization: XH16YH31
TCL identification done
detect device sec info...
detect device sec info finished
sim-lock status: disabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
original data found, method-A
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write: imei
area1 is valid
area2 is valid
area3 is valid
area4 is valid
security area (sec info, part #2) calculation...
customization: CH16YH31
done
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
security area (sec info, part #1) calculation...
use default security area (sec info, part #1) pattern
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcatel-S321A,S321X_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20__system_log__FFFFFFFF_20091009-162917.B0X.bin
Finished, time used: 235 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 10-10-2009, 01:07   #5 (permalink)
WILUNLOCK's Avatar
Member: 726741
Thanks Meter: 1,241
use the latest version of MModule, repairs it with the full...
WILUNLOCK
Old 10-10-2009, 01:27   #6 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 243
Im used verson 2.90 from M module.
What version are using you??
Old 10-10-2009, 16:07   #7 (permalink)
WILUNLOCK's Avatar
Member: 726741
Thanks Meter: 1,241
using MModule" v2.91,for repair imei .....
WILUNLOCK
The Following User Says Thank You to WILUNLOCK For This Useful Post:
b300 unlock done no flash no imei change! scutarus UST Pro II 4 01-12-2009 02:29
SO Still no imei change solution by cruiser??? safeshop Cruiser Suite 2 09-11-2006 14:27
T610 IMEI Change - No Nothing About Phones! mark_tha Sony Ericsson 3 04-03-2004 09:25
imei change but phone has 2 different no. ? reo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 02-28-2002 23:28
5110 IMEI CHANGED,NO NET... tees666za Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-12-2001 11:36
Page generated in 0.31227 seconds with 8 queries
