12-05-2009, 17:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 364992 Status: Offline Thanks Meter: 28 | s521 dead then i flash the phone and restore imei and finish with errors... log: COM3 [VCP0] selected module v2.96 Device: Alcatel-S521X, S521A Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 011439001xxxx ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:7A03:A002 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.CA 4288AA.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_E816CEC1].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: CA4288AA rom info protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, C1CE16E8 address offset: 00000000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 95D provider: S521A-2BCECO1-S2 customization: CD95GD63 customization: XD95GD63 TCL-ID identification done ffs address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 0114380xxxxxxxxx flash: 01227E22442200:18E59F00000000 Backup required data Done ====> Patch required data ... ............................... original data found, method-A Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CD95GD63 customization: CD95GD63 flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... max address is too big, should be recalculated: 08BF8000 error: can not recalculate address range, allowed offset is too small: 00BF4004 error: can't calculate security area (sec info, part #1) Write Done ====> Finalization ... ffs formatting... flash: 01227E22442200:18E59F00000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-S521X,S521A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_CA4288AA_E816CEC1_20 091205-133751.B0X.bin Finished, time used: 137 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-05-2009, 18:26 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Download latest MModule software version from support area and flash phone again. Also you can try to flash phone with another firmware. |
12-05-2009, 19:02 | #3 (permalink) |
Member: 364992 Status: Offline Thanks Meter: 28 | still same error with lastest version.. COM3 [VCP0] selected module v2.98 Device: Alcatel-S521X, S521A Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 011432001292095 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:7A03:A002 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.CA 4288AA.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_E816CEC1].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: CA4288AA rom info protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, C1CE16E8 code offset: 00000000 ffs offset/size: 00C00000/00400000 TCL-ID identification version: 95D provider: S521A-2BCECO1-S2 customization: CD95GD63 customization: XD95GD63 TCL-ID identification done ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 01143800129209 flash: 01227E22442200:18E59F00000000 Backup required data Done ====> Patch required data ... ............................... original data found, method-A Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CD95GD63 customization: CD95GD63 flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... max address is too big, should be recalculated: 08BF8000->00BF4004 error: can not recalculate address range, allowed offset is too small: 00BF4004 error: can't calculate security area (sec info, part #1) Write Done ====> Finalization ... ffs formatting... flash: 01227E22442200:18E59F00000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-S521X,S521A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_CA4288AA_E816CEC1_20 091205-150135.B0X.bin Finished, time used: 151 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-06-2009, 11:22 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | U R Using Pinfinder? If Yes Than Sold + And - Wires Of Pinfinder With Direct Battery Terminal And Use Good Cable/ Battery Must Be Fully Charged Br UMER |
The Following User Says Thank You to maplegsm For This Useful Post: |
Genie dead no power on... [ANSWERED] | lchico | Genie Universal | 1 | 03-29-2010 07:18 |
Alcatel S521 dead after flashing. | bananin | Infinity-Box | 9 | 03-04-2010 13:37 |
connection in s520 & s521 | J3soft | Easy-Unlocker | 1 | 02-06-2009 17:40 |
16 Oct 2008: Alcatel C700 operations improved, S521 is in test | InfinitySupport | Infinity-Box | 16 | 11-21-2008 12:17 |
Alcatel-S521 wanted | InfinitySupport | Infinity-Box | 0 | 10-14-2008 15:44 |
