s535 still locked COM1 [VCP0] selected module v2.58 Device: Spice-S535 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... ........... detect device identification#1 finished identification#1 protocol ver: 02 ver. sw 1: GW23_PCB01_GSM_MT6205B_DN.2_01.BIN ver. sw 2: 2.01, 00000000 ffs offset/size: 00300000/000E0000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[GW23_PCB01_GSM_MT6205B_DN.2_01.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[GW23_PCB01_GSM_MT6205B_DN.2_01.BIN]_20090308-144632.B0E.bin flash: EC22A000000000:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ...... flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: area 0/1 .......... additional parameters detected Ok Special operation Done Write ... flash: EC22A000000000:18E59F00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 215 sec Remove/Install battery now ! how to unlock spice s535 i tried lo unlock......log is here ..... but fone is still locked i wite firmware and sp lock both fone i still locked what to do |
use another mathod than try not unlock then flash |
update ur MModule then post Logs |
COM1 [VCP0] selected module v2.58 Device: Spice-S535 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... ........... detect device identification#1 finished identification#1 protocol ver: 02 ver. sw 1: GW23_PCB01_GSM_MT6205B_DN.2_01.BIN ver. sw 2: 2.01, 00000000 ffs offset/size: 00300000/000E0000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC22A000000000:18E59F00000000 Backup required data Done Patch required data ... ........... lock area found Patch required data Done Special operation ... detecting additional parameters... ................ error: additional parameters detection failed Special operation Done Write ... flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: lock-area-1 Write Done Finalization ... Finalization Done Finished, time used: 42 sec Remove/Install battery now ! try with another method fone is still locked |
bro flash with this file any prob... Spice-S535_IACJ_GW23_PCB01_GSM_MT6205B_DN.2_01_En_Hindi. B0M many time use this file no prob... with me |
i flash with this file now i update my mmodule i try and post result |
COM1 [VCP0] selected module v2.67 Device: Spice-S535 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... ........... detect device identification#1 finished identification#1 protocol ver: 02 ver. sw 1: GW23_PCB01_GSM_MT6205B_DN.2_01.BIN ver. sw 2: 2.01, 00000000 ffs offset/size: 00300000/000E0000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[GW23_PCB01_GSM_MT6205B_DN.2_01.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[GW23_PCB01_GSM_MT6205B_DN.2_01.BIN]_20090308-153438.B0E.bin flash: EC22A000000000:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ................ error: additional parameters detection failed Special operation Done Write ... flash: EC22A000000000:18E59F00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 175 sec Remove/Install battery now ! i tried with new module also but fone is still locked |
hello, Try to use another unlock method. |
